RV.Net Open Roads Forum: Truck Campers: Electrical Help pls
 > Electrical Help pls
Page of 5
ticki2
NH
Posted: 06/21/22 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
maria_bettina wrote:
stevenal wrote:
Once the fuse blowing issue is solved, I expect you'll be dealing with battery capacity. Heating appliances will draw your battery down very quickly.
Yes, I am bummed. I don't know how to heat ourselves at night. Below 40-degrees and it's downright uncomfortable. We have a Little Buddy heater, but not for sleeping. We have Reflectix around the vinyl (we have a pop-up TC), but that's not enough.
Back to the drawing board.
For camping without electric hookup in cool/cold weather it’s pretty difficult to heat the camper without a gas or diesel vented heater . It was as an option on your camper , apparently not taken . It might be time to reconsider .
'68 Avion C-11
'02 GMC DRW D/A flatbed
jimh406
Western MT
Posted: 06/21/22 07:34pm Link  |  Quote  |  Print  |  Notify Moderator
ScottG wrote:
Reflectix is for heat infiltration and isn't intended for cold. Details are on its packaging. So maybe find a better insulation material to put in its place and it could make a big difference!
Reflectix actually works for heat and cold. Preventing heat from going out still means the inside is warmer. Many of us have tried it. It works.
ScottG
Bothell Wa.
Posted: 06/22/22 02:47pm Link  |  Quote  |  Print  |  Notify Moderator
It has minimal effect (again, read the manufacturers info: for temps over 70 degrees).
Pretty much anything, even a blanket draped will work better.
jimh406
Western MT
Posted: 06/22/22 03:06pm Link  |  Quote  |  Print  |  Notify Moderator
So, I guess you use blankets in your windows, skylights, under your bed, and cabinets. We found a roll of Reflectix to be easy to install, and we don't have to launder it.
Seriously though, I'm not sure what minimal means, but we can feel a difference. Apparently, we aren't the only one.
A testimonial of using with an RV on their site. https://www.reflectixinc.com/with-reflectix-i-can-camp-in-the-winter/. Of course, Reflectix could be just spreading misinformation about their product on their site.
Also, there is an entire list of what a DIY might use it for. https://www.reflectixinc.com/applications/diy/
maria_bettina
Auburn, CA
Posted: 06/28/22 10:30pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for all the follow-up posts. This thread has been very informative (to me). I feel like I got a quickie electrical lesson and info on other ways to heat my TC. You guys are the best!!! I can always count on the members of RV.net to help me out.
Yea, we had the $1500 option of an LP furnace which we declined. Believe me, I am kicking myself for that now. I didn't realize how often we'd find ourselves camping in the cold! We have found ourselves at 10k feet elevation and the Little Buddy not working. D'oh. (I guess the cold didn't bother me when we had the travel trailer - haha - oh, how I appreciate all the amenities we had now.)
Thanks again !
jimh406
Western MT
Posted: 06/28/22 10:35pm Link  |  Quote  |  Print  |  Notify Moderator
I believe it's likely you can retrofit a LP furnace. They are essentially a box with knockouts and available in many different sizes.
There are also mini wood furnaces that you can vent to the outside.
Really, there are a lot of options.
Posted: 06/29/22 10:48am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Aerogel may be a solution.
http://www.aerogel.org/
ROFLMAO
Do you just sit on the internet and look for weird impractical solutions to problems that don't exist.
2017 Heartland Torque T29
maria_bettina
Auburn, CA
Posted: 06/29/22 10:52am Link  |  Quote  |  Print  |  Notify Moderator
I am going to look into that again. We don't have a permanent LP on board (just the little canisters), and weight is an issue (hence the bare bones camping) as we are driving a Tundra. I literally made a spreadsheet with weights of all the items we bring. Dang Tundras with their lame max payload. I think ours is 1500#.
joerg68
St. Ingbert, Germany
Posted: 06/29/22 11:19am Link  |  Quote  |  Print  |  Notify Moderator
You may well be near or over your payload rating, but not necessarily over the axle ratings.
The next time you are ready to go camping, take your rig to a scale and get the actual axle weights of both axles.
Compare with the axle ratings on your door sticker.
That will tell you if you have any weight reserves left.
Posted: 06/29/22 11:24am Link  |  Quote  |  Print  |  Notify Moderator
Thanks again !
Nope, Buddy Heaters run out of air at around 8kft, which you didn't mention that you know...so you've effectively verified that they're safe to use and shut off as designed with low O2 (if you understood why it didn't work at 10kft).
It doesn't sound like installing a RV furnace or wood stove (woodstove, really? in a popup full of people? lol love the idea in theory. Not even remotely practical in the OP's scenario/type of camper...) is within your abilities and obviously budget is a huge concern if you bought a new camper with no heater.
A small 5kw-8kw diesel heater would be the most economical and easiest setup for your needs. Would still need to know how to wire it up to your 12V system and install a thru wall exhaust, and have enough battery capacity to run it (just like anything but a woodstove, basically). But the heater will heat the little camper really well it would seem, as a 8kw version is rated to put out about 600% the btus of a Little Buddy. For less than $150 purchase price.
Disclaimer, I have yet to buy or use one of these, but they're pretty popular and widely accepted as being viable sources of heat that use very little fuel and self contained with minimal install requirements.
Page of 5
