RV.Net Open Roads Forum: What Upgrades needed for a 3/4 ton pickup
Search only in Tow Vehicles
 > What Upgrades needed for a 3/4 ton pickup
Posted: 06/22/22 12:44am Link  |  Quote  |  Print  |  Notify Moderator
blt2ski wrote:
Now that I've reread intial better....
If the gas rigs are pre 2014, assuming a 6.0 gas, I would not buy that rig, 2500, 3500 SW or dw! A 6.6 gas is a way better option power wise. If at elevations below 6-7k' best. It will go to the 10-12k feet elevation in Rockies, but your down 30% of HP at those levels. If a single life time trip, go fo for it, if ALL the time over next 3+ years, get one of the diesels from last 10-15 yrs.
An ext cab may be ok payload wise, depending upon options 6.5 bed is 200 LS less than an 8' bed. The longer bed and wheelbase may be better than the loss of payload.
Marty
What’s the aversion to pre-2014? Same power and 6 speed back to at least 2010 as I recall.
I know the body/chassis updated in 2015 if that’s what you meant. But I’m not aware of any major chassis capability changes.
Regardless, OP shouldn’t even consider unless 4.10 gears.
2017 Heartland Torque T29
mkirsch
Rochester, NY
Posted: 06/22/22 06:51am Link  |  Quote  |  Print  |  Notify Moderator
rarin'2go wrote:
What would I have to do to upgrade it to be able to safely tow my 14000 trailer?
Short answer, NOTHING.
You could tow thousands upon thousands of miles with the truck stock, frame pushed down on the axle. As long as everything is mechanically in good shape and working, you'll perfectly safe.
You won't be comfortable, though.
The inability of this forum to differentiate between safety and comfort is unfathomable.
Unsafe is running on bald tires, brakes worn paper thin, wheel bearings growling...
MFL
Midwest
Posted: 06/22/22 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Marty
IIRC, 2014 was the year GM 2500 6.0 went to 4.10 gearing as standard, since earlier standard was 3.73.
Jerry
MFL
Midwest
Posted: 06/22/22 07:04am Link  |  Quote  |  Print  |  Notify Moderator
Also, the 6.0/4.10 combo of that time was rated to tow a FW around 15K. Not saying it would be a comfortable tow, but if OP is towing mostly flat midwest roads, it may be acceptable.
Jerry
Posted: 06/22/22 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Well said.
blt2ski
Kirkland, Wa
Posted: 06/22/22 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Grit,
The 2014+ is that generally speaking, a lot of the gas motors did get significant HP/torque/mpg gains. More so in the under 8400 gvwr relm than 25/35 series. Hence recommendation. If as you point out, the last improvement was 2010 for the 6L gas, Go back that far. At that point in time, finding a rig in decent shape is a crapshoot at best
Even the 3.73 to 4.10 std option is not a big deal. The 6sp/3.73 is better than a 4Lxx with a 4.88 ratio from a get up and go stand point!
Marty
2014 Chevy 1500 Dual cab 4x4
wowens79
Georgia
Posted: 06/22/22 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I've got a Chevy with the 6.0 and 3.73, and tow an 8000lb TT. That is all I'd want to tow with it. Newer ones have a little more HP, and 2 more gears, but it's gonna struggle with 14k.
If looking at 2020 or newer, look at Fords 7.3 gasser. It way out performs the Chevy 6.6 gas.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
spoon059
Just north of D.C.
Posted: 06/22/22 02:48pm Link  |  Quote  |  Print  |  Notify Moderator
Michelle.S wrote:
Maybe it's just me, but not sure I would be trying to pull a 14K Fifth wheel with a gasser unless it was all down hill.
This being RV.net in the tow vehicles section, I've got to disagree with you! [emoticon]
If all my towing was downhill, I'd rather have the diesel with integrated exhaust brake!
2015 Ram CTD
2015 Jayco 29QBS
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/22/22 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
Then you would have a Diesel and not a Gasser, the down hill part was tongue and cheek.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
ford truck guy
Pennsylvania
Posted: 06/22/22 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
That is actually a valid argument spoon ! ! ![emoticon]
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
