RV.Net Open Roads Forum: Tech Issues: New bathroom sink replacement bead sealer
 > New bathroom sink replacement bead sealer
SFVdave
Posted: 06/22/22 12:46am Link  |  Quote  |  Print  |  Notify Moderator
I am replaceing my bathroom sink and it has a white gooey paste like bead around it making it difficult to pull off. I have it all cleaned up and the new sink ready to go in. What's the bead? Does look like a very soft version of plumbers putty. Can't used Dicor or anything that will dry hard.
ACZL
UPstate,NY
Posted: 06/22/22 04:52am Link  |  Quote  |  Print  |  Notify Moderator
Not sure what type of sealant was used, but in the stick house, I've used a clear plumbers putty w/ very good results. Had to scrape off anything left w/ a razor blade 1st before installing sink then the putty.
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
Dutch_12078
Winters south, summers north
Posted: 06/22/22 06:52am Link  |  Quote  |  Print  |  Notify Moderator
RV manufacturers often use the same butyl putty tape to install sinks that they use to install doors, windows, vents, etc.
LLPT Butyl Seal Putty Tape White 1 Inch
Dutch
2001 GBM Landau 34' Class A
SFVdave
Posted: 06/22/22 07:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, I have a roll on hand.
Dutch_12078
Posted: 06/22/22 07:40am Link  |  Quote  |  Print  |  Notify Moderator
That's good then. If you've used the putty before, then you're probably aware that i may squeeze out for a time, calling for retightening until it settles down. That's the same as using plumbers putty. Over the years I've used the two pretty much interchangeably depending on which I had on hand when needed.
Cummins12V98
on the road
Posted: 06/22/22 08:23am Link  |  Quote  |  Print  |  Notify Moderator
First you need to tell us what type of sink. Stainless that has clips to draw it down tight or self rimming that just sets in place?????
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
SFVdave
Posted: 06/22/22 11:10am Link  |  Quote  |  Print  |  Notify Moderator
It's a JR plastic small bathroom sink. Has 4 plastic clips that screw into vanity top. Question, Out here in Southern California the temperature is in high 90's. Do you think leaving the butyl tape in the sun will make it softer and more sticky and help molding into shape? I want the tape made into a roll.
time2roll
Posted: 06/22/22 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I use DAP brand white silicone kitchen and bath adhesive sealant from Home Depot for similar projects at home and would use same in the RV.
675w Solar pictures back up
way2roll
Wilmington NC
Posted: 06/22/22 12:17pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed, it's still a sink regardless if it's in an RV.
2023 FR Sunseeker 2400B MBS
Gdetrailer
PA
Posted: 06/22/22 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
^^^THIS^^^
Have a china bathroom sink in my sticks and bricks, came with tube of Kitchen/bath adhesive/sealant from the manufacturer of said sink. Fixture does not have clamps or screws to hold it down, relies solely on the adhesive/sealant to hold it in place and seal the perimeter.. Installed it better than 30 yrs ago, hasn't leaked or moved..
Much better option than using butyl rubber caulking/tape..
