RV.Net Open Roads Forum: Class A Motorhomes: Floor Wax - ZEP
 > Floor Wax - ZEP
rtz777
Batavia NY
Posted: 06/22/22 07:20am Link  |  Quote  |  Print  |  Notify Moderator
About 8 years ago I coated my 02 Bounder with Zep floor wax and have since reapplied every couple of years. This year it needs to be all removed due to flaking. I am using ZEP floor stripper and its removing the wax easily, however, what was white with the wax on is now yellow once the wax is removed? What can I do to remove the yellow and return it to white again?
Thank you!
rgatijnet1
Posted: 06/22/22 07:59am Link  |  Quote  |  Print  |  Notify Moderator
You can have a body shop TRY color sanding and see if they can remove the top "yellow" layer of paint and get down to the original white color. This is all assuming that the paint is thick enough to allow color sanding without going through to the body panel primer. Keep in mind that this was a floor wax and there is no telling what damage it may have done to the original paint. A body shop should be able to try a small area to see if it the paint is salvageable.
RLS7201
Posted: 06/22/22 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
I have been using Zep Wet Look for several years. I strip and recoat about every 4 years. It really keeps my ol Bounder looking good. I have not experienced any color issues when striping off Zep
Zep wet look is NOT a wax. You have to polish when applying a wax. Zep Wet Look Floor Polish is an acrylic topcoat. No polishing necessary.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
Bruce Brown
Northern NY
Posted: 06/22/22 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
I highly doubt an '02 Bounder has full body paint - it would be a white fiberglass sheet so no paint to sand or primer to rub through too.
That said, sanding and buffing might help a little but I fear it's most likely just yellowed with age. Unpainted 20 year old fiberglass won't stay new forever.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
chast
Marlton, NJ
Posted: 06/23/22 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure you have gotten all of the old ZEP off? Try re-applying the stripper and agitating with a non-abrasive scrubbing pad. My guess is that you still have residual floor finish in addition to yellowing of the Fiberglas with age,
chartrue2@aol.com
RLS7201
Posted: 06/23/22 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Chast may have hit upon something. I use a green scotch bright when stripping the old coating off.
My 95 Bounder didn't yellow with age............
Richard
Dale.Traveling
Newport News, VA
Posted: 06/27/22 12:42pm Link  |  Quote  |  Print  |  Notify Moderator
More than likely the yellowing is from sun exposure and the normal aging of the fiberglass. I stiped off a sun stroked black graphic several years before I started using Zep and there was a stark white shadow where the graphic used to be.
2006 Hurricane 31D built on a 2006 Ford F53
 > Floor Wax - ZEP
