bsqrd
Tucson, AZ
Hello,
I've been told that an item to check for a weak flame other than LP pressure is the position of the knurled knob on the solenoid. Anyone know how (pull-to-turn or just turn) and to what exact position (CW/CCW, slot level) to set it?
Thanks,
Bob
mordecai81
United States
The slot on mine is horizontal. I have no idea if its a 1/4 turn to shut off or if it's possible to adjust it.
dougrainer
Carrolton, Texas
I guess it depends on how old the refer is. IF the refer has been operating on LP just fine, then the position of the manual cut off is not a concern. The "T" of the actual handle should be pointing at the incoming copper/rubber LP supply line. In 43 years as a Tech, I have NEVER had that valve as a problem with Flame. Either it was ON or OFF. Never halfway. Doug
PS, your N7 should have a slot screw.
