RV.Net Open Roads Forum: Fifth-Wheels: 5th wheel front tripod
 > 5th wheel front tripod
valhalla360
No paticular place.
Posted: 06/23/22 06:30am Link  |  Quote  |  Print  |  Notify Moderator
We used to have one and it helped but it was a hassle for shorter stays as you would have to pull it out and then store it.
A bit more expensive but the JT strongarms (or clones) are more effective and less effort.
As to why:
- Wheels are on springs, so they will still allow bouncing.
- Simple vertical stablizers can only provide resistance to vertical motion. Side to side and front to back motion is unchecked. Adding a device that resists side to side and front to back will take a lot more of the motion out.
PS: As much as people like to claim rock solid, there will always be a little movement.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
on the road
Posted: 06/23/22 07:40am Link  |  Quote  |  Print  |  Notify Moderator
All jacks on ground the wheels do not bounce. YES the RV can have some lateral movement. MobileSuites rams have a 5 degree slant out at the bottom helping with this. All six jacks on the ground along with my boxes under each jack my 24k RV is VERY stable.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
StirCrazy
Kamloops, BC, Canada
Posted: 06/23/22 07:52am Link  |  Quote  |  Print  |  Notify Moderator
my old 5th I had one and it helped but it had the rear stabalizer jacks like the cheep campers had 15 years ago. my new 5th has the auto leavling system, so more heavy duity linera jacks front and rear and is pretty much rock solid when set up. the tripod worked on my old 5th but the new one it didnt make a difference. so it got given away. if your back end is solid but the bedroom area moves you have other issues.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
valhalla360
No paticular place.
Posted: 06/23/22 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Assuming a relatively long trailer with 4 stabilizers on the corner, the frame will flex enough in the center that you can feel it. This is why many of the larger trailers have gone to the 6 stabilizer approach. It puts one close to the axles to stop that flexing.
fj12ryder
Platte City, MO
Posted: 06/23/22 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Just an aside: we use the back ramp door as a patio quite frequently and since the rear jacks of the 6 point level system is just to the rear of the tires, there is a fair amount of movement when we're back on the "patio". We got one of those Valterra stabilizers: Valterra Stabilizer . While they look really chintzy, they do an admirable job of taking the movement out when we're back on the "patio".
Howard and Peggy
"Don't Panic"
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/23/22 09:34am Link  |  Quote  |  Print  |  Notify Moderator
MORryde now sells a unit similar to that Valterra unit, but inserts into the rear Receiver Hitch
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Puddles
Lafayette, Indiana
Posted: 06/23/22 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
With the cheap lightweight frames that are now installed by manufactures, I think any support you put under the pin can only help when you're using the trailer while unhooked.
HTML
TXiceman
Full Time RVer
Posted: 06/23/22 06:08pm Link  |  Quote  |  Print  |  Notify Moderator
We tried one for a time and finally decided it was not worth the effort. I tried to sell it but wound up giving it away to a noobie to try out.
Ken
Amateur Radio Operator.
StirCrazy
Posted: 06/24/22 06:29am Link  |  Quote  |  Print  |  Notify Moderator
actualy there are measurments on weather you need 4 or 6 from the maker of ground control. surprising enough mine measures long enough for 6 (39.5 feet) but only had 4 and its rock solid.
TravelinDog
Nevada
Posted: 06/24/22 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses guys, I was just curious.
General consensus = waste of $$.
Just say no to the payload police ">
