Jq1953
Leland, nc
Roof a/c with not come on, neither will the manual fan setting work. Fuses/breakers seem ok.
I’ve tried both shore power and generator power. Any ideas?
midnightsadie
ohio
just a though, is there a switch under the stat? on off? a battery in the stat? don,t no any more about them.
PastorCharlie
NC
On mine the EMS relay for the AC stopped working. Wired bypass and it works great.
2112
Another Tread with same issue
In Doug We Trust
2013 KZ Durango 2857
dougrainer
Carrolton, Texas
PastorCharlie wrote: On mine the EMS relay for the AC stopped working. Wired bypass and it works great.
Usually, depending on the Brand EMS, the EMS only stops the Compressor from running not the fan. Intellitec stops full function. PCS brand stops the compressor and not the fan. Doug
EMD360
Arvada, CO
I’m the other thread. I replaced both the run and fan capacitors. Turns out my Coleman Mach 15 does not have a separate start capacitor. Nor does it have a speed selector switch. I still have a problem with the high fan option. The high fan wire sparks with power applied. But the air is working again and the fix was pretty easy.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
