RV.Net Open Roads Forum: Truck Campers: New shocks?
 > New shocks?
TxGearhead
Posted: 06/24/22 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
I've got 65,000 miles on my 2018 RAM. Cummins, 4X4, long bed, DRW. I carry the Bigfoot occasionally and the Landmark 5th occasionally more. Both 4,000# loads. Only mod is a Hellwig BigWig. I'm assuming I need new shocks.
My priority is as smooth a ride as possible. 90% highway use.
I realize this is a subjective issue.
Your recommendations?
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
jimh406
Western MT
Posted: 06/24/22 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I like my Bilstein 4600 shocks. You will get a lot of other recommendations.
Southern California :(
Posted: 06/24/22 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Installing new shocks is important IMO. The make of the shocks (if a quality manufacturer) isn’t important.
JimK-NY
NY
Posted: 06/24/22 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
Why do you assume you need new shocks? With any luck they will last for several more years.
Are you having ride issues?
Bedlam
PNW
Posted: 06/24/22 08:06pm Link  |  Quote  |  Print  |  Notify Moderator
If your suspension is cycling more than once after going over a bump, you need shocks. Otherwise, you need more spring.
* This post was edited 06/25/22 09:11am by Bedlam *
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD
greenno
Clairemont Cal.
Posted: 06/24/22 08:15pm Link  |  Quote  |  Print  |  Notify Moderator
If you want a bit softer ride go with Bilsteins. I had 5100's on my previous truck and have Fox 2.0's on my present truck all carrieng the same 990 camper.
The Fox's are difinetly stiffer. Better off-road and with a load but they are more firm than the Bilsteins if you want softer.
Hear good things about Rancho to, adjustable from what I can tell.
Good luck.
Geo*Boy
Unknown
Posted: 06/24/22 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
Bilstein 4600’s
MORSNOW
Mountain Home, ID
Posted: 06/25/22 08:36am Link  |  Quote  |  Print  |  Notify Moderator
I've been running Bilstein 4600's for the past 5 years, great ride and a durable shock.
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD
7,220# Truck/10,400# Camper Fully Loaded
tcguy
SW Ohio
Posted: 06/25/22 08:57am Link  |  Quote  |  Print  |  Notify Moderator
I am running Bilstein 4600 shocks on my 2018 F350 diesel 4x4 CC dually with an AF 990 TC and am happy with the ride.
Posted: 06/25/22 10:34am Link  |  Quote  |  Print  |  Notify Moderator
Bilsteins are a good middle of the road not too soft not super hard, lasts forever shock.
 > New shocks?
