RV.Net Open Roads Forum: Truck Campers: New shocks?
 > New shocks?
TxGearhead
Posted: 06/30/22 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
^Yeah I'm going to take the rears down to the mid 30's and see if that helps before I spend a sh@*load of money on shocks.
Dang I didn't know shocks had gotten that expensive,
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
Hemi Joel
Minnesota
Posted: 06/30/22 07:15pm Link  |  Quote  |  Print  |  Notify Moderator
TxGearhead wrote:
I've got 65,000 miles on my 2018 RAM. Cummins, 4X4, long bed, DRW. I carry the Bigfoot occasionally and the Landmark 5th occasionally more. Both 4,000# loads. Only mod is a Hellwig BigWig. I'm assuming I need new shocks.
My priority is as smooth a ride as possible. 90% highway use.
I realize this is a subjective issue.
Your recommendations?
Look at your springs when the truck is loaded. There's probably some short, very thick overload springs. Maybe the bottom leaf of the main stack, or maybe an additional spring up above or down below the main leaves. If you've got the main spring pack compressed down to the point that the overload springs are engaged, the ride is going to be rough. My truck was beating me to death because with the camper in it was on the overload springs and they were stiff as a board. So I took them out and added a few of the longer, thinner leaves. And put in some air bags. Now it rides much much smoother.
2018 Eagle Cap 1163 triple slide, 400W solar, MPPT, on a 93 Dodge D350 Cummins, DTT 89 torque converter, big turbo, 3 extra main leafs, Rancho 9000s rear, Monroe gas magnums front, upper overloads removed, home made stableloads, bags.
stevenal
Newport, OR, USA
Posted: 06/30/22 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
You may find running on under inflated tires to be more expensive.
'18 Bigfoot 1500
Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Posted: 07/01/22 11:15am Link  |  Quote  |  Print  |  Notify Moderator
Did you assume the OP meant hauling his camper or heavy load with lower tire pressures, or do you not understand load vs inflation?
2017 Heartland Torque T29
JIMNLIN
Oklahoma
Posted: 07/01/22 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I've used other shock brands including Bilstiens on my 3/4 and one ton play and service trucks and always went back to the good old Rancho 9000 shock for carrying max rear axle loads from heavy GN trailers or my 10' 6" truck campers.
Bilstiens were just ok for my use on 1/2 ton trucks I've owned. Nice mushy ride like new OEM shocks but they did last much longer than OEM.
Posted: 07/02/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Good to hear some good recommendations for Ranchos, as I have $600 worth of Bilstein paper weights that I need to try to return. And need to find alternatives to the otherwise very nice 5100s!
specta
utah
Posted: 07/02/22 11:08am Link  |  Quote  |  Print  |  Notify Moderator
I ran 35 psi in BF Goodrich M/T on an empty 3/4 4wd for years and they wore perfectly even.
I run 50 psi front 45 psi rear in my current 3/4 ton when empty and they have all worn perfectly even too.
I wouldn't think that running 35 psi in the rear tires of an empty dually would cause premature tore wear.
Other than tire pressure I don't see any other way to improve the empty ride of a 1-ton pickup.
Kenny
2011 Chevy 2500 HD 6.0L 4wd
1976 Ford F-250 6.4L 4wd
Posted: 07/02/22 11:40am Link  |  Quote  |  Print  |  Notify Moderator
^ This.
And tire size/capacity plays a role on pressure obviously. But suffice it to say, the overwhelming majority of HD truck rear tires can and should be in the minimum to maybe 40-45 psi range for no load/light load scenarios.
37s on our Ram, I run 25-30 psi empty, rear. Heck only run 45-50 psi when the toyhauler is hooked up. Weight bearing, no wdh.
stevenal
Newport, OR, USA
Posted: 07/06/22 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
By under inflated, I mean not maintaining the proper inflation for the load. OP did not state for what loading he would be reducing pressure. No assumption made by me.
TxGearhead
Posted: 07/07/22 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
^^ No load.
 > New shocks?
