hpdrver
Mansfield, Texas
I am trying to set up a home using the two Wally’s I use with my rv. The home is wired with coax from multiple rooms going to the attic. There is also a single coax line going from the outside to the attic. It is not easy to add another coax line going from outside to the attic. I have purchased a dish 1000 satellite dish with a quad lnb to install outside to feed this single coax line that goes to the attic.
I have read goggle search on how to split dish satellite signal to two receivers but am confused by them. How do I split the dish signal to feed two Wally receivers. Thanks
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
Ranger Smith
Wherever the rig is parked
One of these possibly
Satellite Signal Splitter
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
PButler96
Midwest
A dish 1000 has 3 lnbs not 4. I assume its a western arc dish going by the location in your info. What you would need to do is have a separate coax run to each wally from the lnb as the lnb is also your "switch".
Or two separate runs from the lnb to a solo node, then one run from solo node to a power pass two way splitter, then a run from each splitter tap to each wally.
I have a burn barrel in my yard.
Have you tried putting the dish in the Attic? Might be an issue in rain/snow but otherwise.
And if you have an attic window facing either west or south with a bit of positining you might even be able to avoid rain issues.
CA Traveler
The Western States
I'm having a hard time imagining a dish working in a attic, not that i've ever tried it. In my experience rain on the surface of the dish is not a problem, but rather the weather in the 23,000 mile distance to the satellite and/or wind that moves the dish.
2014 Grand Cherokee Overland
Bob
chuckbear
You CAN NOT put a dish under any roof and get reception.
CA Traveler
The Western States
chuckbear wrote: You CAN NOT put a dish under any roof and get reception. X2 But I'm not sure about glass in a window?
Cptnvideo
Arizona - most of the time
I'm not positive, but I think RF energy (satellite signal) will pass thru fiberglass but not glass due to the chemical composition of glass.
For the OP, switch to a Hopper 3 with 2 wireless Joeys.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 5 206AH LiFePo4 batteries for 1030 ah
PButler96
Midwest
Cptnvideo wrote: I'm not positive, but I think RF energy (satellite signal) will pass thru fiberglass but not glass due to the chemical composition of glass.
He wants to use the two wallys he already has in his RV, in his house when hes not using the RV. Why would he want to buy a hopper 3 and two Joey's? Then he would have to reconfigure all the wiring in his RV amd the dish on his RV may not even support a hopper 3.
Cptnvideo
No wiring to reconfigure in the house or RV. A single co-ax cable from the dish to the Hopper 3. That's it.
