RV.Net Open Roads Forum: Technology Corner: Dish Tv help needed
 > Dish Tv help needed
hpdrver
Mansfield, Texas
Posted: 06/25/22 02:53am Link  |  Quote  |  Print  |  Notify Moderator
I am trying to set up a home using the two Wally’s I use with my rv. The home is wired with coax from multiple rooms going to the attic. There is also a single coax line going from the outside to the attic. It is not easy to add another coax line going from outside to the attic. I have purchased a dish 1000 satellite dish with a quad lnb to install outside to feed this single coax line that goes to the attic.
I have read goggle search on how to split dish satellite signal to two receivers but am confused by them. How do I split the dish signal to feed two Wally receivers. Thanks
Texas Two Step
2021 Coach House 272XLFR
2020 JL Jeep Wrangler
Ranger Smith
Wherever the rig is parked
Posted: 06/25/22 03:54am Link  |  Quote  |  Print  |  Notify Moderator
One of these possibly
Satellite Signal Splitter
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
PButler96
Midwest
Posted: 06/25/22 04:30am Link  |  Quote  |  Print  |  Notify Moderator
A dish 1000 has 3 lnbs not 4. I assume its a western arc dish going by the location in your info. What you would need to do is have a separate coax run to each wally from the lnb as the lnb is also your "switch".
Or two separate runs from the lnb to a solo node, then one run from solo node to a power pass two way splitter, then a run from each splitter tap to each wally.
I have a burn barrel in my yard.
Posted: 06/25/22 05:01am Link  |  Quote  |  Print  |  Notify Moderator
Have you tried putting the dish in the Attic? Might be an issue in rain/snow but otherwise.
And if you have an attic window facing either west or south with a bit of positining you might even be able to avoid rain issues.
CA Traveler
The Western States
Posted: 06/25/22 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I'm having a hard time imagining a dish working in a attic, not that i've ever tried it. In my experience rain on the surface of the dish is not a problem, but rather the weather in the 23,000 mile distance to the satellite and/or wind that moves the dish.
2014 Grand Cherokee Overland
Bob
chuckbear
Posted: 06/25/22 08:40am Link  |  Quote  |  Print  |  Notify Moderator
You CAN NOT put a dish under any roof and get reception.
CA Traveler
The Western States
Posted: 06/25/22 09:50am Link  |  Quote  |  Print  |  Notify Moderator
X2 But I'm not sure about glass in a window?
Cptnvideo
Arizona - most of the time
Posted: 06/25/22 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I'm not positive, but I think RF energy (satellite signal) will pass thru fiberglass but not glass due to the chemical composition of glass.
For the OP, switch to a Hopper 3 with 2 wireless Joeys.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, 3kw inverter/charger, 3 206AH LiFePo4 batteries
PButler96
Midwest
Posted: 06/25/22 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
He wants to use the two wallys he already has in his RV, in his house when hes not using the RV. Why would he want to buy a hopper 3 and two Joey's? Then he would have to reconfigure all the wiring in his RV amd the dish on his RV may not even support a hopper 3.
Cptnvideo
Posted: 06/25/22 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
No wiring to reconfigure in the house or RV. A single co-ax cable from the dish to the Hopper 3. That's it.
