RV.Net Open Roads Forum: Tech Issues: 2008 Roadtrek Versatile 190 mystery battery
 > 2008 Roadtrek Versatile 190 mystery battery
Rdwrer
British Columbia
Posted: 06/25/22 06:58am Link  |  Quote  |  Print  |  Notify Moderator
I am having various electrical issues in my Roadtrek, but before I post about those, there seems to be a third battery in the vehicle that I'd like to find. I disconnected the chassis battery and the coach battery, and somehow, lights in the back (overhead light above the kitchen and bed) still come on.
I bought the rv second hand, and the previous owner has done some great modifications, but I haven't come across any mention of this other battery in the documentation. Any ideas appreciated!
midnightsadie
ohio
Posted: 06/25/22 07:34am Link  |  Quote  |  Print  |  Notify Moderator
I have a sprinter and there could be one under the passenger seat.
dougrainer
Carrolton, Texas
Posted: 06/25/22 08:06am Link  |  Quote  |  Print  |  Notify Moderator
State WHERE your Chassis battery and your COACH battery are located. Also Brand of chassis. Mercedes or Ford. Mercedes can have 2 chassis batteries. One under the front hood on drivers side and the other under the drivers seat floor board. Then the coach battery is located in the rear area, under the chassis by the hitch. Doug
bob_nestor
murphy
Posted: 06/25/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
I believe that Roadtrek only used Mercedes and Chevy chassis in 2008 and the Versatile 190 was Chevy 3500 based, as was my 2010 210 Popular. (PleasureWay used Mercedes and Ford mainly with a mirror image floor plan to Roadtrek.) The coach batteries are located on the passenger side in a pull out drawer rear of the side entrance door. The chassis battery is located in the engine compartment.
For what it's worth I saw the same "issue" with my 210 Popular and ever located where the phantom power was coming from.
Rdwrer
British Columbia
Posted: 06/25/22 09:37am Link  |  Quote  |  Print  |  Notify Moderator
Yep, it's a Chevy chassis, 3500. The batteries are as you described, Bob: chassis under the hood, and coach behind the side entrance door, passenger side, in the drawer.
I guess I'm happy to hear you had a phantom battery too, though if I can't find it, it'll potentially make troubleshooting more difficult.
(If you happen to remember the user "senf" in this forum, it was his and his DW's vehicle. I've searched his posts for any reference to adding a battery but no luck. He references "batteries" a couple of times, but does not list them in the mods in his signature)
Rdwrer
British Columbia
Posted: 06/25/22 10:42am Link  |  Quote  |  Print  |  Notify Moderator
FOUND IT!!
Turns out there is another drawer behind the passenger-side rear wheel. There is no panel "flap" like for the one just behind the side access door, you have to take off the panel altogether to get at it. That battery hasn't been maintained at all in the 4 or 5 years since I got it, so it's now being replaced. Fingers crossed, that solves the other issues...Thanks all!
Skibane
San Antonio, TX
Posted: 06/25/22 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
^That sounds like the perfect candidate for a sealed AGM or gell battery - i.e., doesn't require adding water occasionally or cleaning corrosion off the terminals, and can be tucked away in just about any dark corner.
dougrainer
Carrolton, Texas
Posted: 06/25/22 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Remember, you have to make SURE the Coach Converter system can charge AGM/Gel batteries correctly. Doug
dougrainer
Carrolton, Texas
Posted: 06/25/22 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
When I work on any RV that at first you cannot find the battery, I look for this on the sidewall or van side. Doug
https://www.amazon.com/Valterra-A10-3300........=9027230&hvtargid=pla-492389436851&psc=1
