RV.Net Open Roads Forum: Tech Issues: Leak near Valve/Tank Connection
 > Leak near Valve/Tank Connection
Posted: 06/26/22 07:47am Link  |  Quote  |  Print  |  Notify Moderator
Use This to post pictures
Even if his vent pipe is too far down inside his black tank it shouldn't leak. Fix the leak.
It could just be the weight of the water causing it to leak at a poorly sealed joint. Fix the leak
2013 KZ Durango 2857
CA Traveler
The Western States
Posted: 06/26/22 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Even IF the vent is plugged or dropped into the liquid as soon as you flush the tank is vented and liquid will flow in (and gasses out) until the tank is full. This is given that the toilet empties into the top of the tank, hard to imagine otherwise.
2014 Grand Cherokee Overland
Bob
Posted: 06/26/22 09:54am Link  |  Quote  |  Print  |  Notify Moderator
And a guy has a leak and half the people start discussing the virtues and drawbacks of tank level monitors….
2017 Heartland Torque T29
