yellow dog
PA
Anyone make any modifications to the tire valves on a GMC / Chevy 3500 DRW? Outer and inner wheel I find are difficult to air up and check do the location of valves on aluminum wheels. I am planning on adding extensions to inner wheels, but outer valve faces inward making access somewhat awkward.
edited 06/27/22 11:05am by yellow dog *
CA Traveler
The Western States
Extensions are more likely to leak. Install metal dually wheel stems like Borg and 2 short outward facing metal stems in the front if you don't have internal pressure sensors.
2014 Grand Cherokee Overland
Bob
chiefneon
Livingston, TX
Howdy!
I’m having a even harder time with my rear DRW now that I have added TPMS. I installed flow through TPMS thinking I would be able to access them and now it is even worse.
“Happy Trails”
Chiefneon
Retired JSO
North Georgia Mountains
My long air Chuck works for both inside and outside. Used on class C, class A diesel and DRW trucks.
ksss
Eastern Idaho
Yep the above is the trick.
2020 Chevy 3500 CC 4X4 DRW D/A
2013 Fuzion 342
2011 RZR Desert Tan
2012 Sea Doo GTX 155
2018 Chevy 3500HD CC LB SRW 4X4 D/A
2015 Chevy Camaro ZL1
blt2ski
Kirkland, Wa
I prefer the straight shaft for dinner, obviously rear angle for outer. Some rims have really small openings, you can't get the angled inner dual to work. I have this issue with my IHC. Did not have the issue with my 3500 series dually s. I do admit, the straight inner works better.
Marty
2014 Chevy 1500 Dual cab 4x4
chiefneon
Livingston, TX
Howdy!
Thanks.
I have a couple of those and still can’t connect to air it up.
“Happy Trails “
Chiefneon
miltvill
Ft. Lauderdale FL
I put 4" curved metal extensions on the inner rear wheel. They are short enough that they don't vibrate against the wheel. The caps are close to the rim and difficult for me to take off so, I changed the caps on the other valve stems to a longer cap I can easily take off to check the tire pressure or add air. After 2 years they haven't leaked.
2020 GMC Denali\Duramax 3500HD Dually Crew Cab
Sold-Trail Cruiser TC23QB
bucky
Raleigh metro
The inner wheel valve stems are a straight shot. Why would curved extensions help?
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
fj12ryder
Platte City, MO
CA Traveler wrote: Extensions are more likely to leak. Install metal dually wheel stems like Borg and 2 short outward facing metal stems in the front if you don't have internal pressure sensors. Absolutely, I've tried three different extensions, and they all leaked eventually. One leaked immediately, and the other two took 6 months, and a year...but they all leaked.
Howard and Peggy
"Don't Panic"
