time2roll
jaycocreek wrote: Quote: They are strongly against floating! see why.
I've read that before and from others but I don't understand why someone like Victron would have float in there charge controllers for lithium with no way to disable it..So is it really bad or lol
Lifepo4 parameters seems to be liking asking 10 different doctors what's wrong with me with 10 different answers...lol The only trouble with float is the voltage is set too high. Keep in the 13.2 to 13.4 zone and all is good. Most "lithium" converters float 13.6 all the way to 14.6 volts.
675w Solar pictures back up
BFL13
Victoria, BC
"Thank you for the information. I have a Battle Born 100AH battery and a Progressive Dynamics 60amp convertor, so I guess .6C. The combo has been working well for two years now. I do unplug the PD once the battery is charged."
Seems right although BB allows 14.6 for a while until balancing has happened at least.
How do you tell your BB "is charged" ? Also what do you mean by "is charged"?
I see 3-tons also disconnects after his batt bank is full and if on shore power, he runs on LFP batt for 12v and shore power for 120v, even though he has a PD converter that can sit at 13.6 doing the 12 v while also floating the LFP at 13.6.
One complaint with the Dakota Blurb is he says a normal charger will only charge an LFP to 80% and then shut down. What weird "Sales" talk is that? He explains it, but it turns out he is not talking about any "normal" charger/converter at all. Oh well--"Sales" has its own rules ("all's fair in love and war" )!
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
Microlite Mike
NW Washington State
One needs to realize that while there are hundreds of manufacturers (if not hundreds, it certainly seems like it) there are really only two "Types" of LiFePo4 batteries widely used in RV's. One is based on "Prismatic" cells which are rectangular cells connected in series and "Cylindrical" cells which as their name implies, built from numerous cylindrical cells connected in series/parallel configuration.
C-Rate can be influenced greatly in the above types by their ability to dissipate heat during charging.
Battleborn uses Cylindrical cells, others use Prismatic. Instructions for one type may not be appropriate for another type.
Since I have Battleborn batteries (2x 100ah) I charge at the max output of my PD9160L Converter (57 amp avg) until charge current drops to <0.3 amp and shut off converter (I use the shutoff module PD sells for their 9100 series charger with TCMS "port"). Since most of the time I boondock and use my solar panels with Victron Smart MPPT controller, it charges to 14.4 volts then drops to 13.5 volts after an adaptive absorption charge (@14.4v). Controller decides how long the absorption charge needs to last based on DOD and it's calculated need for cell balance. Some absorption times can run up to an hour and some as little as 2 minutes, all depending on DOD.
I think that since LiFePo4 batteries are relatively new, and a total change from what we've all been used to with the 150 year old Lead/Acid tech, many think they're fragile and need to be babied. I think that in reality they're a lot more durable than people believe and the quality batteries have a quality BMS that takes most of the worry out of the equation. I charge mine then go camping. They get charged daily as needed (solar of generator) and when not camping I recharge when I get home then shut batteries off. Switch on charging while preparing for next trip and they charge from my Tow Vehicle via a DC-DC charger.
No more worry about corrosion, sulfation, low electrolyte levels, and since they're mounted inside they don't get cold when camping and needing recharging (no need to charge while in storage). Battleborn's are in their 4th season and I wouldn't be surprised to see them still going strong when my time on this planet is up.
I also own a Plug-In Hybrid (Volt) and it just stays plugged in when I'm not driving it. It's on it's 6th year and battery capacity shows no measurable loss of capacity yet.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
3 tons
NV.
BLF said:
“How do you tell your BB "is charged" ? Also what do you mean by "is charged?
I see 3-tons also disconnects after his batt bank is full and if on shore power, he runs on LFP batt for 12v and shore power for 120v, even though he has a PD converter that can sit at 13.6 doing the 12 v while also floating the LFP at 13.6v”
Close, but for added clarity, ‘IF on shore power’, I discontinue charging beyond an occasional cell-balancing, but never disconnect the battery (except for long term storage at about 50’ish % SOC…), I simply shut down the converter-charger…I would also add that you’ll know when it’s charged by watching on a LFP compatible SOC meter, the ‘to & fro’ dance of amps vs volts until end of cell-balancing when amps stops…
Here’s what I’d penned:
“Fair enough,
I’d only point out (unless I’m misunderstanding…) that this charging scenario seems to assume a practice of keeping a charged battery on an active converter-charger - but other than for ‘occasional’ cell-balancing (an activity requiring 100% SOC…) why do so with a LFP??
I would counter that this apparent consternation (possibly a FWC thingy?) mainly applies to ‘unattended set and forget’ shore power charging (as is typical with lead batts)…But even if using a ‘less that ideal’ charging device for LFP, one need ask how realistic of a scenario is this??
And, to arrive at the dreaded ‘the slide-out won’t work’ gottcha, it suggest that once ‘shore power’ charging has been completed (to whatever level?), for protection, an LFP battery needs to be sequestered….Why is this??
I’d counter that one can merely shutoff the onboard converter-charger (at it’s breaker…), at which time 12v power will come from the now charged, still active battery (minor loads only, and possibly with some solar assist?), while leaving shore power connected for 120v heavy appliances (e.g. air cond, etc)…
Regardless of the charging source (and, charged to whatever desired SOC?? - definitely NOT a lead acid thingy!!), one can simply opt to discontinue charging and just live for a considerable time off the battery’s deep reserves…This is exactly what I do, and with 400a/hr LFP and 660w of solar, seldom the need for shore or genny power - the last time I ran the genny was about 11 mos ago (and have since circumvented America…), and if in a park, ONLY use shore power where shading prevents harvest or when using air conditioner…In most other scenarios, the pass-thru inverter (concurrent with harvest) does the job…Just Saying”…
3 tons
pianotuna
Regina, SK, Canada
time2roll wrote: pianotuna wrote: At 0.3 C the "rapid charging" feature disappears compared to my favorite chemistry. Quote: 166 amps is too slow?
On a 100 amp Li it would be 30 amps yes? So where does 166 come from? (scratching my head)
Regards, Don
time2roll
On a 100 amp Li it would be 30 amps yes? So where does 166 come from? (scratching my head) Check your signature
pianotuna
Regina, SK, Canada
time2roll,
I have twin battery banks. My biggest charging source is a Magnum 3000 watt inverter/charger. It maxes out at 127 amps. The recommended maximum charging rate for the existing telecom jars is 107 amps, or about 19%. If I did go to LiFePo4, I'd still not be able to charge them significantly faster without getting a larger inverter/charger.
My personal choice for replacements would charge at 0.25 C and do not taper. Assuming 400 amp-hours charging would be 100 amps. LiFeP04, again assuming 400 amps would be 120 amps. That would mean 20 minutes less charging time on Li. But Li don't even enjoy being charged to 100%--so in real terms there may be zero difference in charging time.
There is a savings in cost especially if you "roll your own" Li. But as I do use my RV at -37 c (-34 f), Li are pretty much not going to happen. As to having them in the heated area of the RV There would have to be major modifications to make them fit in the heated space. If I were still full time it could work. However, I'm personally not comfortable with ANY house bank inside the living quarters.
In short, LiFePo4 are great where it is warm--but not too hot either. They simply do not meet my particular needs.
BFL13 wrote: .
Some LFP owners on here ISTR have taken to charging at lower voltages hoping for longer battery life. Perhaps it needs to be established which is correct--lower amps or lower voltage?
Lower amps or lower voltage.. Well..
First I've heard claims (not comment) suggesting some oh wait. ot LFP so I won't even finish that thought.
Now. Every battery has what is called "internal resistance" And of course the wires connecting it to the converter/charger have resistance.
Current = Voltage divided by resistance.
So when bulk charging lower voltage = lower amperage.
now one you get to absorption phase. Well that still applies..
The FLOAT voltage is the only time where changing voltage actually changes the battery voltage.
In order to push more amps into the battery you inrease the charging voltage..
NOW: the danger.. Pushing too much voltage for too long a period.. That damages the battery.
Li type batteries, according to some should be STORED at about 50% charge or so at least one source tells me. I have not the means to verify.
StirCrazy
Kamloops, BC, Canada
kinda, but not realy. if you put 0.3 amps into your favorite chemistry and into LFP and both are at say 20% SOC the LFP will get to 100% long before the other one. even the bulk phase will be faster, due to the lower internal resistane of the LFP less of the energy sent to recharge it will be converted to heat and hence more is availble for actual charging. I am not saying this phase is a houge advantage but it is noticable. and when we hit the top part of the charge the LFP charging speed does run away from other types as there is no drop off untill just before the finished line.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
StirCrazy
BFL13 wrote: Some "sales" statements here, but also some possibly good info of interest.
One thing is they found longest life (most cycles) was to charge at 14.4v but at lower amps at 0.3C.
They say 14.4 vs 14.6 to reduce stress, and recommend their own charger (of course!) which is single stage 14.4--BUT they say shut charging down-disconnect- once the charger says the batt is full. (light comes on---what makes that light come on? oh well)
Anyway, it covers some of what has come up on here lately.
https://dakotalithium.com/2021/09/22/how........ge-dakota-lithium-and-lifepo4-batteries/
I am not sure of most intentionaly chose a converter that charges at 0.3C or less. I think its a matter for most (myself included) the converter in my camper is a 45amp and I put in a 310AH LFP battery so I chagre at 0.15C from that and my solar will put out 23Amp at peak so the fastest I can charge is 0.22C even if I had a 90Amp converter that would still be less than 0.3C. so its more of an issue of how expensive of a converter/charger do you want to buy and if you only use 100AM over night is it worth the extra money to replace that in one hour as aposed to a few hours? so in a way just comon sence is limiting the charge rate. the thing is in the space a person can put a 200AH 6V set up, I could easily put two, maybe three, 310AH batteries but I would still have that same charging setup except Li compatable. and I do run mine at 14.6 charge and it holds for 90 min after reaching full charge then drops to 13.5. this is all set up on my solar as my converter is just a single stage for now so it only gets used if I need a quicker deeper charge, but for the most part the solar has me charged up before noon if I run the furnice over night.
Steve
