I would say repair or replace. Easy to do in either case (Replace is likely the better option) and not all that expensive.
Though I got a lot of "no longer available" when I searched for one.
I did NOT check Camping world.
opnspaces
San Diego Ca
I read everybody's posts and it just seems to me that you possibly have an obstruction in your orifice or in the burner itself. I would pull the burner and then see if the orifice on the feed tube can be unscrewed with a tiny wrench. If so pull it out and see if you can see sunlight through the tiny hole in the middle. If you have compressed air try to blow the orifice out.
If the stove orifice's are removable then try swapping the burner and the burners matching orifice from a working position and put them in the failed burner position.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
