Mr. C
SW Virginia, USA
2020 Keystone Cougar 26RBS. After a 4hr trip home, low voltage prevented the slide from opening. The fridge was running during the trip. Plugged in and opened the slide. The next day I had the battery tested and it's fine. I verified that the truck charges the battery. Yesterday, with battery at 13.6, I unplugged. Fridge was running. This AM, 6.3 volts.
What direction do I need to head? Only the fridge and propane detector were running on the battery.
2020 Keystone Cougar 26RBS "Pressure Relief 4"
2017 Silverado LTZ 6.2 4x4
MM2 USN 1970-75
USS Canisteo AO-99
USS Miller DE-1091
"Knowledge is good". Emil Faber
WayneAt63044
St. Louis, MO
Do you have a 12 volt compressor refrigerator? If so, what is the power consumption vs. the battery specs? Just one battery?
2012 Forest River V-Cross Vibe 826VFK
pulled by 2009 Ram 1500 Quad Cab Hemi
MFL
Midwest
If plugged in and showing 13.6, does not mean battery was fully charged. However if battery showed only 6.3, after just being unplugged overnight, with minimal draw, I'd say you need a new battery.
Did a competent person load test your battery, and say it was fine? Unless your battery has been abused, often times allowed to drop to 50% or less, it should have lasted more than two years.
A four hour trip should have charged the battery some, but if very low to begin with, not enough to operate the slide on it's own.
I'd have it load tested again, as it should not drop to 6.3 overnight. I think you will be needing a new battery.
Jerry
enblethen
Moses Lake, WA
Check the DC distribution panel for battery voltage with shore power disconnected and tow vehicle disconnected. Possible that the charge line from TV is not providing power. Possible that battery fuse in distribution panel blown.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Cambria, California area
An RV battery or batteries drawn down to 6.3 volts is toast. You have an issue, yes, but buy new batteries when solved.
StirCrazy
Kamloops, BC, Canada
Mr. C wrote: 2020 Keystone Cougar 26RBS. After a 4hr trip home, low voltage prevented the slide from opening. The fridge was running during the trip. Plugged in and opened the slide. The next day I had the battery tested and it's fine. I verified that the truck charges the battery. Yesterday, with battery at 13.6, I unplugged. Fridge was running. This AM, 6.3 volts.
put your fridge on propane, and get new batteries. if you ran it down to 6V its toast. I am saying to put your fridge onto propane as when I looked up your model it saud propane/electric fridge so I am asuming you have a 2 or 3 way.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
enblethen
Moses Lake, WA
OP: You say "battery". Do you have only one?
What size is the battery you have in the rig? Is it 12 volt or do you have a pair of six volters? If six volters, they are wired wrong
klutchdust
Orange, California
Lwiddis wrote: An RV battery or batteries drawn down to 6.3 volts is toast. You have an issue, yes, but buy new batteries when solved.
So if a battery gets discharged to that point it is no longer usable, even if recharged?
I had a battery that was dry, sitting in the garage zero charge in it. I filled with distilled water, trickle charged it for a few days and it went back in service with no issues. A load tester can be had at HF that is equal to or as good as any I have ever used and will give you accurate analysis of the batteries condition.
Mr. C
SW Virginia, USA
The battery was tested at Advance Auto Parts. They said it had more than the stated CCA. Battery is the original/3yrs old. The fridge has been running on propane. I will have the battery retested somewhere else, and will hook up a different battery and retest. Hoping it's just the battery and not something else.
I have verified that the TV is charging the battery, and this is reflected on the InCommand screen.
pianotuna
Regina, SK, Canada
Mr C,
How many amp-hours is the battery?
Regards, Don
