RV.Net Open Roads Forum: General RVing Issues: Traveling with Propane on
 > Traveling with Propane on
Page of 7
Surgtech94
Midwest
Posted: 06/29/22 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Do you travel with the propane on to run the refrigerator? What safety measures need to be taken? We haven’t been traveling more then 1 1/2 hours from home, so our fridge hasn’t cooled down much, but planning on some longer trips. Thanks In Advance
IDman
Oklahoma
Posted: 06/29/22 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, we always ran with LP on UNTIL we stopped for fuel. I would pull over before we got to the station and turn it off at the cylinder. After fueling, I would pull out of the station, or at least away from the fuel pumps, and turn it back on. Then I would enter the TT to make sure the frig was lit again.
Safety first!!
Surgtech94
Midwest
Posted: 06/29/22 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Safety first!!
Thank you. Have you ever had to relight the stove to make sure propane was still flowing to the fridge? One last question, at home do you start off with the fridge on electric and then switch to propane when you leave ? Or just start off with the propane at home before you leave? Thank you
rdhetrick
Posted: 06/29/22 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Safety first!!
What is it about fueling up that makes you want to shut off the propane?
When I had a trailer, the propane was always on until it needed to be switched or until I put it in storage. Now, the only time I turn it off is when refilling the tank.
Rob - Solo Full Timer
2017 Winnebago Travato 59G
Former 2006 Mandalay 40E
enblethen
Moses Lake, WA
Posted: 06/29/22 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
I leave the refer in "auto". We run with the propane on.
Turning off propane is a safety item when refueling. Chances of enough build up to blow up would be very minimal. Not saying not to do it or to do it!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Dutch_12078
Winters south, summers north
Posted: 06/29/22 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
We shut off any appliances using propane in our motorhome when refueling to prevent the ignition sequences from possibly igniting gasoline fumes, but not the tank itself. With a trailer, the distance from the fuel fill point pretty much negates any danger risk. We no longer have an absorption fridge, so no propane needed there, but we do run our two propane furnaces as needed when traveling in cold weather. We also use the stove at rest stops to make lunch sometimes.
Dutch
2001 GBM Landau 34' Class A
BB_TX
McKinney, Texas
Posted: 06/29/22 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Always.
Theoretically there is a very slight chance that while filling up your and your RV was sitting next to a gas pump and the refrigerator vent panel was very near that gas pump hose as it was pumping gas and the wind was exactly right to lift the heavier than air gas fumes up and blow those into the refrigerator vent and the refrigerator was currently cooling and the fumes reached the burner, then yes, a fire is possible.
Likewise if someone sprayed gasoline into the refrigerator vent while it was on ………..
Diesel fumes are not explosive like gasoline fumes. Diesel is more like charcoal lighter fluid as far as flammability.
* This post was edited 06/29/22 08:35pm by BB_TX *
LadyRVer
Posted: 06/29/22 07:24pm Link  |  Quote  |  Print  |  Notify Moderator
I didn't travel with refrig on LP for years. Then, once I started doing it, I was fine. I do turn off the refrigerator and LP before I put fuel in. Then, pull away from the pumps and start it all back up.
I usually cooled it down 24 hours prior to leaving (before full-timing) with either electric or LP, whichever was available.
time2roll
Posted: 06/29/22 07:48pm Link  |  Quote  |  Print  |  Notify Moderator
Fridge, furnace, water heater is all on if needed. Fridge is aways needed. Never left the stove on while in motion although if it was a MH I would not hesitate to use it if needed.
Conveniently the fuel port is not close to any of the propane items so all can run continuous.
675w Solar pictures back up
CA Traveler
The Western States
Posted: 06/29/22 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
Best to turn off propane for a gas rig at a fuel station due to volatility of gas.
But there are thouslands of posts on this subject... [emoticon]
2014 Grand Cherokee Overland
Bob
Page of 7
