sprintnut
Altoona, PA.
Water comes out spigots and other places with pump shut off and no hose connected to camper? There is some water in the fresh tank.
Your advice and/assistance welcomed.
Russ 1999 Newmar Kountry Star fifth wheel
Russ
2000 F350 & 1999 Newmar Kountry Star fifth wheel.
MFL
Midwest
Seems obvious that the pump is not truly switched off. Unless the pump is running the water cannot continue to flow, other than a bit of residual pressure allowing slight water flow for a bit.
I suspect your on/off switch has failed. Most pumps make a little noise when operating. Some are fairly quiet, but you should hear it running.
Jerry
midnightsadie
ohio
MFL pretty much said it all. you,ll get a bit of a drips but not running .
pinesman
virginia
Some rigs have an accumulator tank which would hold the water pressure a little longer but it will still stop after a little bit
way2roll
Wilmington NC
Maybe some more information is needed. How long do you continue to get water? I get water out of my spigots with everything turned off for quite a while and more pressure than I would expect. Even with the batts off so I know the pump isn't running. I think 2 things are at play; the system maintains pressure until all the water is emptied from the lines, and as things heat up during the summer - especially if you had your water heater on, pressure builds long after you shut the pump and WH off. I'll go to my camper in storage and despite emptying my lines when I put it away, I still get a little water to come out to wash my hands. Infrequently the power will go out at the house and I'll have water for quite a while until all the pressure is relieved. Same principal.
If however you think you have evacuated the lines and you still get constant pressure, yeah, your pump is still on. I think you would hear that running though wouldn't you?
CA Traveler
The Western States
If the tank overflow line is plugged then there could be pressure in the tank. Air in the hot water tank can also cause a limited flow as can residual pressure in the water lines.
2014 Grand Cherokee Overland
Bob
