RV.Net Open Roads Forum: Tow Vehicles: Field tricks to remove inside dually wheel?
Search only in Tow Vehicles
 > Field tricks to remove inside dually wheel?
Bedlam
PNW
Posted: 07/01/22 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
10 hrs waiting on emergency service for an inside DRW flat. What's the trick getting them free? I have the truck up on a 12-ton bottle jack and the outer removed. Inside is stuck to the hub even though it was off less than year ago.
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
Fisherman
Angus, Ontario, Canada
Posted: 07/01/22 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
You might be able to get a small steel chisel between the rotor/drum on the rim openings and give it a couple of wacks with the tire iron. it's worked for a couple of cars that had seized rims. Then apply anti seize to the mating surface, sparingly. Another trick I used on trucks if you don't have a heavy load, loosen the wheel nuts about 1/2 to 3/4 turn and make some really sharp left right turns, that often cracks them loose too.
time2roll
Posted: 07/01/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
I would drive very slowly with the lugs loose.
675w Solar pictures back up
BobsYourUncle
Calgary Alberta Canada
Posted: 07/01/22 07:01pm Link  |  Quote  |  Print  |  Notify Moderator
I went through that a number of years ago. Try as I may, that thing wasn't coming off the hub.
Here is how I freed mine:
I carry a lot of tools with me including an 8 pound sledgehammer. I put a block of wood across the wheel so it straddled the top of the rim and clobbered it with the sledge. It took a few tries but I eventually dislodged it. Gotta be careful not to hit the rim directly. I rotated the wheel between hits.
Mine was rusted onto the hub at the very back. It was the rust holding it on there.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Cummins12V98
on the road
Posted: 07/01/22 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Shock and awe. Hit it with some type of steel you hold in one hand and big hammer in the other. Place steel between the lugs and WHACK it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Bedlam
PNW
Posted: 07/01/22 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I found running ratchet straps through the rim and putting a wooden block centered on hub put enough even force on the rim to free it. Just when I got it free, I got a call that service was 5 minutes out. I'll post up some pictures tomorrow when we are on the OR coast.
IB853347201
Eastern Ontario
Posted: 07/02/22 06:15am Link  |  Quote  |  Print  |  Notify Moderator
Sledgehammer or pry bar, it's what the tire shops use.....
2010 Suncruiser
Cambria, California area
Posted: 07/02/22 07:52am Link  |  Quote  |  Print  |  Notify Moderator
I’m interested in those pictures, Bedlam. Never encountered this issue.
JRscooby
Indepmo
Posted: 07/02/22 08:27am Link  |  Quote  |  Print  |  Notify Moderator
Glad you solved the problem. Are you open to suggestions? Pull all the wheels, and put anti-seize on all the hubs to reduce future problems.
Geo*Boy
Unknown
Posted: 07/02/22 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Wow Bedlam, my truck has never seen winter salt and never will, but the next time I have a chance I am going to pull the duals and put never seize on the hubs.
