RV.Net Open Roads Forum: Tech Issues: Using my phone hotspot for the tv.
 > Using my phone hotspot for the tv.
valhalla360
No paticular place.
Posted: 07/08/22 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
valhalla360 wrote:
Gdetrailer wrote:
Digital broadcasting via ATSC (the digital TV standard now used) has a lot of flaws, local RF noise severely impacts the reception, rain, snow, trees all affect the distance and then with many more UHF frequencies available than VHF really impacts the distance. UHF is strictly "line of sight", doesn't bend with the Earths curvature, signal will skip over deep valleys between hills and buildings, trees or other solid obstacles simply block it..
Yes, much more sensitive and less range. Not technically correct but effectively the power that used to go into one channel is now split up.
Also, unlike the old analog where the picture might be a little fuzzy but you could watch it. Digital is there or it's not. So when you are at marginal range, it usually means nothing or frequent freezing of the image.
Actually all of the stations ATSC output power ....
As I said, "not technically correct".
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Acampingwewillgo
Posted: 07/08/22 10:55am Link  |  Quote  |  Print  |  Notify Moderator
Dutch_12078 wrote:
Acampingwewillgo wrote:
Get on the "Visible" group rate for "unlimited" talk,data and hot spot. Granted its not really unlimited but I use it just as a back up when needed. My wife and my T-mobile phones on the geezer plan give you quite a bit of data/hot spot.
Back to Visible.....my plan is 25.00 a month on Verizon network but I think they still offer AT&T network, if that works better for you. I still do have Sat but streaming is nice to have when you want it/need it.
The Visible unlimited talk, text, and data is in fact unlimited. It is a prioritized service that can slow down on highly congested towers, but that only lasts as long as the congestion lasts.
Visible is wholly owned by Verizon and only works on Verizon towers. They do not offer any service on AT&T towers. Tracfone, also owned by Verizon, does offer phones on AT&T's and T-Mobile's towers, as well as there own, but no unlimited data service.
Thank you for setting the record straight on what "Visible" offers. I got in on the deal a few years back and the basic use of our Visible phone is as a back up to our T mobile phones during our RV'ing trip both for connectivity and streaming.
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
punomatic
Pacific Northwest
Posted: 07/08/22 10:58am Link  |  Quote  |  Print  |  Notify Moderator
I started out to stream TV by tethering to my phone. I quickly discovered that Spectrum's "unlimited" plan throttles the data my phone uses as a hot spot at 5GB, even though I am supposed to get 20GB before throttling. I guess if I want to watch TV on my phone, I'm covered. Might check your provider for the details on how much unthrottled data you are allowed when using your phone as a hot spot.
DW and Me
2016 Riverside White Water Retro 195
2014 Nissan Titan SL Crew Cab
Formerly, I used to work for the department of redundancy department.
Life in Black and Blue
d1h
Indiana
Posted: 07/08/22 08:08pm Link  |  Quote  |  Print  |  Notify Moderator
I have used my AT&T hotspot with my roku. As long as you have a decent cell signal it works really well.
austinjenna
Columbus, Ohio
Posted: 07/09/22 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I saw a tiktok of someone in an rv that uses the t-mobile 5g unlilmited internet for 50 a month
Link
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
udidwht
Seattle
Posted: 07/18/22 02:45am Link  |  Quote  |  Print  |  Notify Moderator
T Mobile 5G wifi home internet
No contract and $50 per month. The device can be taken with you in your RV and used while on the road. I did just such (Renton - HB, Ca and back for 3.5 weeks) I purchased a 300w inverter that plugs into cigarette light. Worked great!
1994 Fleetwood Southwind Storm
P-30 chassis 7.4L 454 TBI 58,301 miles and counting....(as of 06/08/19)
VIN# 1GBJP37N4R3314754
Flight System Generator man 360 (PM me)
