enblethen
Moses Lake, WA
OP: Should be able to find a generic remote that will operate the TV. Should be able to find manual for TV online. What is brand of TV? Any name on booster power supply?
Check the for 12 volts DC to power supply for booster.
There is some stations that still broadcast over the air. Not many networks!
Call Forest River for them to identify antenna.
edited 07/06/22 06:59pm by enblethen *
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Gdetrailer
PA
enblethen wrote: OP: Should be able to find a generic remote that will operate the TV. Should be able to find manual for TV online. What is brand of TV? Any name on booster power supply?
Chances are the TV is Furion, Jensen or a few other low quality RV brand TVs. Most of those off brand RV TVs will be made in China and will have some common chassis which a universal infrared remote may have a code for a different brand that will work.
One of the major keys to digital OTA broadcasts is they use a "virtual" channel assignment now days. This means the channel number of the station may or in most cases is not the old legacy analog channel.
With this new virtual channel setup, one must rescan the TV tuner each time they move to a new town/city even if it is only 50 miles away.
As far as "some stations" broadcasting, no stations were removed from broadcasting, they did not go bankrupt or fail or quit broadcasting, they are still there.
What did happen is digital broadcasting does not transmit as far with the original power level and antenna systems. Many stations ended up losing broadcast area coverage, some petitioned FCC for increased power, antenna height and higher gain antennas. For some it required adding additional "translator" (translators act like a repeater and rebroadcast the stations signals on a different frequency) station licenses and new remote translator locations to claw back the lost coverage.
Digital broadcasting via ATSC (the digital TV standard now used) has a lot of flaws, local RF noise severely impacts the reception, rain, snow, trees all affect the distance and then with many more UHF frequencies available than VHF really impacts the distance. UHF is strictly "line of sight", doesn't bend with the Earths curvature, signal will skip over deep valleys between hills and buildings, trees or other solid obstacles simply block it..
Dutch_12078
Winters south, summers north
Acampingwewillgo wrote: Get on the "Visible" group rate for "unlimited" talk,data and hot spot. Granted its not really unlimited but I use it just as a back up when needed. My wife and my T-mobile phones on the geezer plan give you quite a bit of data/hot spot.
Back to Visible.....my plan is 25.00 a month on Verizon network but I think they still offer AT&T network, if that works better for you. I still do have Sat but streaming is nice to have when you want it/need it.
The Visible unlimited talk, text, and data is in fact unlimited. It is a prioritized service that can slow down on highly congested towers, but that only lasts as long as the congestion lasts.
Visible is wholly owned by Verizon and only works on Verizon towers. They do not offer any service on AT&T towers. Tracfone, also owned by Verizon, does offer phones on AT&T's and T-Mobile's towers, as well as there own, but no unlimited data service.
Dutch
2001 GBM Landau 34' Class A
dodge guy
Bartlett IL
I e tried using my phone as a hotspot. It doesn’t do very good at that. What I did find was that mirroring my I phone with the Apple HD connector works great. I can watch You Tube, Hulu, Netflix or anything else without much of an issue. Every once in a while I’ll get some buffering, but it’s minor.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
theoldwizard1
SE MI
Lwiddis wrote: Do you know how to scan for available OTA TV channels? Rare I can’t find one, two or more.
BUYER BEWARE ! Most HD TV antennas are a SCAM !
You can buy a good one for around $50-$75 dollars. The better ones will have 2 or 3 "bow ties" on the front and a square "grid" (reflector) behind them. Getting it as high as reasonably possible off the ground IS IMPORTANT !
When you get to your campsite and have setup, go to antennaweb.org. It will show the closest stations and the general direction they are in.
pbeverly
South Carolina
We watch VERY LITTLE TV while camping. I have always been able to pull in a few local stations which I want mainly for local weather and news.
I use a Chromecast for movies or TV shows. The catch is I download content and stream it to the Chromecast on the TV. Wifi is required and I use my phone as a hotspot. The advantage is very little bandwidth is used as the content is on my phone.
As I said, we watch little TV, but if the weather is bad we have some things downloaded to watch. If we take grandkids I let them choose some movies prior to trip that I can download ahead of time.
Ridgeway, SC
way2roll
Wilmington NC
klutchdust wrote: enblethen wrote: What antenna do you have?
Do you have in the wall power supply (booster)? Does if light up?
Make and model?
What is make and model of TT?
2015 Work and PlayUltra by Forest river. Second owner. TV that came with it did not have a remote. It's a brand that I have not heard of. The antenna looks like a flying saucer on a short pole. I travel solo fishing and attending desert racing events. I would like to have some reception of some kind even if it were some local news channel. As far as movies,netflix etc that is not important. There is a booster switch behind the TV . I have no problem replacing the TV and the antenna on the roof if necessary. Satellite TV I have no interest in.
So, what are my options. Having a TV is not a necessity but let's see whaat you guys come up with, thanks
If it's only local news you are after, streaming would be overkill. Add to that, many local channels don't stream anyway and if they do it's after the actual airing. Find a universal remote that works with your TV and scan the channels. that said, in the middle of nowhere you may have difficulty finding channels. You can always just get news on your phone.
BTW, you'll still need a remote for your TV even if you stream. At a minimum, power, channels, volume etc
2023 FR Sunseeker 2400B MBS
valhalla360
No paticular place.
Gdetrailer wrote: Digital broadcasting via ATSC (the digital TV standard now used) has a lot of flaws, local RF noise severely impacts the reception, rain, snow, trees all affect the distance and then with many more UHF frequencies available than VHF really impacts the distance. UHF is strictly "line of sight", doesn't bend with the Earths curvature, signal will skip over deep valleys between hills and buildings, trees or other solid obstacles simply block it..
Yes, much more sensitive and less range. Not technically correct but effectively the power that used to go into one channel is now split up.
Also, unlike the old analog where the picture might be a little fuzzy but you could watch it. Digital is there or it's not. So when you are at marginal range, it usually means nothing or frequent freezing of the image.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Gdetrailer
PA
valhalla360 wrote: Gdetrailer wrote: Digital broadcasting via ATSC (the digital TV standard now used) has a lot of flaws, local RF noise severely impacts the reception, rain, snow, trees all affect the distance and then with many more UHF frequencies available than VHF really impacts the distance. UHF is strictly "line of sight", doesn't bend with the Earths curvature, signal will skip over deep valleys between hills and buildings, trees or other solid obstacles simply block it..
Actually all of the stations ATSC output power goes into the same size as the old analog channel frequency allotment of 6 Mhz. The analog NTSC used the entire 6Mhz band allotment - upper and lower frequency guardbands (this was to reduce bleed over to adjacent channels) to deliver one channel.
NTSC vs ATSC
ATSC is all about transmitting digital data packets using very high digital compression (MPEG-2 which can be as much as 50 to 1 compression) which allows stations to decide to use all or only part of the 6Mhz band they are allotted. They can choose to have as many as 6 SD video streams or combination of one or several HD streams. Some may even elect to have only one HD stream and use the left over bandwidth to provide private data transmissions for other commercial use.
HERE is a good "primer" on ATSC and digital TV transmissions.
On edit..
From the last link I posted..
![[image]](https://i.imgur.com/9nymeq8l.jpg )
Click For Full-Size Image.
This is a representation of how the 6Mhz channel bandwidth use compares between ATSC and NTSC.. Ultimately and ironically the final output is more like AM (Amplitude Modulated) which if one has ever tried to listen to a AM radio transmission then one would understand the reason as why ATSC is much more sensitive to noise..
edited 07/07/22 08:58am by Gdetrailer *
Tom_M
New Hope, MN
klutchdust wrote: Was discussing with a few friends that my TT does not have reception on the TV. I no longer have a satellite carrier and don't know much about the antenna on my 2012 work and Play trailer. One person commented he purchased a smart Tv with roku and uses his phone as a hotspot. So, what amount of data would it use. What are the downsides of this. Antenna upgrade? thanks in advance. The Winegard Sensar IV (aka Batwing) is considered about the best RV TV antenna available. It has the broad elements that are needed for receiving VHF channels well. Second choice would probably be the King Jack. It does not have the broad elements so it works poorly for the VHF channels but is on par with the Sensar IV for UHF channels. About 25% of TV stations are now broadcasting on VHF so for full coverage the Sensar IV would be the better choice.
A former forum member did an extensive test comparing the two antennas. Here's a link to his test: SCVJeff's test.
If you intend to go with the Sensar IV, make sure there is room for the antenna when it is stowed. I had to install mine so that it stowed to the side rather than to the rear. I have had this for many years and have had no problems.
Both antennas are directional and need to be aimed toward the TV transmitter. Antennas Direct is a good site to locate where the TV transmitters are.
I live in Minneapolis and all the network affiliates here stream their local news in real time. I suspect this is true for most TV markets.
For cellphone I use Visible. It is the only service I know of that has truly unlimited data including hotspot use. If you join a 'Party Pay' plan the monthly cost is $25/month total, no added fees. It has worked very well for me.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
