RV.Net Open Roads Forum: Class A Motorhomes: Onan Running Problems
 > Onan Running Problems
haste maker
alabama
Posted: 07/07/22 11:48am Link  |  Quote  |  Print  |  Notify Moderator
I have a 2007 32BA Allergo with a 7000 watt Onan gas generator, the generator ran yesterday for 10 hours then quit, when I tried to restart it was very difficult to restart, after I did get it started again it ran for 10 minutes, and quit again, it was difficult to restart this time also, but did start only to run for 2 minutes...I didn't try to restart again. The red light on the dash switch was flashing off & on, each time the generator quit...It does have plenty of gas RV tank is full, all filters were changed 2 weeks ago, and it has been running great until now.
Anyone have any ideas of where I need to start looking to repair the generator?
* This post was edited 07/07/22 12:14pm by haste maker *
Retried Teamster
2007 Allergo
ken1961
Posted: 07/07/22 12:16pm Link  |  Quote  |  Print  |  Notify Moderator
https://generatorsage.com/why-onan-generator-starts-then-shuts-down/
Ken
older_fossil
USA (fulltiming)
Posted: 07/07/22 02:12pm Link  |  Quote  |  Print  |  Notify Moderator
If the light on the dash start switch is blinking in a repeating pattern, this is very likely an error code. The Onan 4000 in our previous Class C would blink an error code on the start/stop switch on the generator. First thing I would do is check the oil level. I had a problem with our gas Onan stopping after running a while that turned out to be a bad fuel filter.
Art
Art & Barbara
2016 Tiffin AB 37AP
2011 Jeep Grand Cherokee
haste maker
alabama
Posted: 07/07/22 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks I will try this...I did fill it to the top mark on the drip stick & it was close to the low mark before the filters were changed.
PhilipB
MO
Posted: 07/07/22 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
My 5500 on toy hauler in signature was boiling the fuel, then shutting down. We made a shroud to channel the exhaust side away from the air intake side. The symptoms made is appear to be a clogged carb/fuel filter or bad fuel pump.
2015 Ram 2500
2013 Raptor 310TS
midnightsadie
ohio
Posted: 07/08/22 05:41am Link  |  Quote  |  Print  |  Notify Moderator
fuel line colapesed fuel line. try a different fuel source clean plug.
allbrandauto
maryland
Posted: 07/08/22 07:39am Link  |  Quote  |  Print  |  Notify Moderator
fuel pump fuel pump fuel pump
Rickyrocket
Coventry,RI
Posted: 07/09/22 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
If indeed the fuel pump pull it and look for a part number,Google the part number fuel pump,do not list Onan,most likely it will be a pump for a riding lawnmower costing $25 or so not the $300 for the Onan part.
FloridaRosebud
Melbourne
Posted: 07/10/22 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
I tried that and bought an aftermarket pump for my 5500. It would not fit. Bolt holes would not line up, and there was no way to mod it to make it work. Bought the Onan and fit like it was supposed to.....buyer beware.....
Al
haste maker
alabama
Posted: 07/10/22 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Update according to the code on my unit "47" the problem is "Ignition Fault"...so I will taking it to an Onan repair shop...thanks for all the info..
