RV.Net Open Roads Forum: Travel Trailers: Leaking fresh water tank
 > Leaking fresh water tank
LITEPHIL
AZ
Posted: 07/10/22 06:53am Link  |  Quote  |  Print  |  Notify Moderator
Taking off for the mountains for the week, so I investigate more when I get back but thank you
2022 Chevy Silverado RST Duramax NHT
1954 Chevy 3100 Carryall 4x4
2008 Salem T23FBL
04 FXDL Harley
Lantley
Ellicott City, Maryland
Posted: 07/10/22 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
I was able to find the exact tank for my 2012 trailer. I purchased the unit new to my dismay the tank had already been repaired once by the factory or dealer prior to me aquiring the trailer.
I ordered the tank on line and swappede it out with the leaking tank.
I consider it a 7 job on a scale of 1-10.
No too difficult but you do have to remove underbelly and wrestle old tank out and new tank in but it's doable.
Contact manufacture or decent dealer to inquire about replacement tank.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Baja Man
Inland Empire, CA
Posted: 07/17/22 08:57pm Link  |  Quote  |  Print  |  Notify Moderator
I repaired my FW tank a few years ago on a TH I owned. Previous owner tried to use silicone to repair....wrong! Removing the silicone took longer than the repair! I used a plastic repair tool I purchased from Harbor Freight; it worked perfect! It's like soldering plastic. Just take your time, go slow, and it does work. Never had a leak again!
HF Plastic Welding Tool
2003 Ford F-350 XLT Super Duty, Crew Cab, V10 (6.8L); 4X2; Standard Bed; SRW; 4R100 trans
2011 Outback 250RS - Anniversary Edition
Equal-i-zer 10K
LITEPHIL
AZ
Posted: 07/29/22 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Sorry to not get back about this sooner. I have a guy that has a place that will spin weld it for $150 if I take the tank out. I have another trip to the mountains next week, so I will pull the tank when I get back. Thank you all
Sjm9911
New Jersey
Posted: 07/29/22 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Yup , was going to mention that was an option. Good luck and tell us how it turns out.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
LITEPHIL
AZ
Posted: 09/19/22 07:24am Link  |  Quote  |  Print  |  Notify Moderator
Sorry for not getting back sooner but I wanted to make a trip and make sure my repair was sound. My spin weld guy flaked out on me so I contacted a RV dealer near by that was recommended and he welded it for me. $200! I wanted a new tank but I guess they repair them all the time as some had advised me here.Little pricey but what isn't these days?
Thank you for the help!
ktmrfs
Portland, Oregon
Posted: 09/20/22 09:16am Link  |  Quote  |  Print  |  Notify Moderator
the vast majority of plastic fresh water tanks are a material that is easy and best fixed by spin welding. Holds up great. In fact in these tanks most of the fitting that aren't molded in are spin welded at the factory. Most repair shops that do spin weld repair have an assortment of spin weld patches on hand. Basically the patch or fitting is spun against the tank and friction melts the junction, stop, let it cool and it's welded together.
For black/grey tanks, most are ABS which again is easy to fix, but instead of spin welding, solvent welding is done. Basically either use ABS glue on small cracks or use abs sheet material to bridge the break and solvent weld.
2011 Keystone Outback 295RE
opnspaces
San Diego Ca
Posted: 09/20/22 10:33am Link  |  Quote  |  Print  |  Notify Moderator
$200 is a bit steep. But if it continues to hold it will be money well spent.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
JRscooby
Indepmo
Posted: 09/20/22 10:40am Link  |  Quote  |  Print  |  Notify Moderator
I dropped the tank cut a hand-sized hole in the top so could use glue on the inside of crack. Then patched the hole on the top well enough that nothing could fall in.
ralph day
Ontario Canada
Posted: 09/26/22 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Speaking of fw tanks...I was filling with water before setting up camp and couldn't get the water to go in as usual...it burped and splashed back like never before. You could feel air being forced out the inlet past the hose. Hmmm. Crawled under the coach and found the overflow tube, sure enough a mud dauber wasp had plugged it. An ignition key for the truck (old school) was the right size to dig the mud out. Filled fine after that. I guess that's another thing to check when readying the coach for travel.
As water goes in air is forced out the overflow tube, unless it's plugged.
