Cummins12V98 wrote: WHY are you unloaded your front axle when hitched with a tow behind???
Because that’s what literally happens when you apply a significant load aft of the rear axle…
Unless one can transfer most/all the tongue weight away with the wdh.
1L243
Oregon
I'm under my GVWR and I am under my GCWR so I don't think there is anything dangerous going on here. As far as the airbags go they are an assist just like the WDH. I would not count on airbags to support all the weight of the truck and trailer. I so expect them to improve my ride.
1400 pounds of TW puts me between 10% and 15% which is where I want to be.
I don't think I will be adjusting the WDH any tighter.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
Cummins12V98
on the road
Grit dog wrote: Cummins12V98 wrote: WHY are you unloaded your front axle when hitched with a tow behind???
He has a weight distribution hitch correct??? Setup they ADD weight to the front axle NOT remove it. He is removing weight.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
^Yes, but with those numbers I assumed weight bearing since that made more sense.
Seems light for the front of a diesel too, but idk?
1L243
Oregon
Cummins12V98 wrote: Grit dog wrote: Cummins12V98 wrote: WHY are you unloaded your front axle when hitched with a tow behind???
I have a WDH with 1500 pound bars.
You drop enough weight like 1400 pounds of TW and 300 pounds of cargo on the back bumper your going to lighten the front end. I was happy it was only 200 pounds. The WDH is cranked about as far as I want to crank it.
bucky
Raleigh metro
I want my 5er level, the truck not so much. Trucks have suspensions for a reason.
Puma 30RKSS
