RV.Net Open Roads Forum: Class A Motorhomes: Tire pressures
 > Tire pressures
RB414921
Connecticut Hill, New York
Posted: 07/10/22 05:02am Link  |  Quote  |  Print  |  Notify Moderator
When traveling with your RV your maximum tire pressures are 110 when it reaches 110 is the general rule of thumb to stop and lower the pressure back to the starting point of 90 to 95 psi? I just bought a brand new set of coopers for my motorhome and this is what I’ve been doing with tires before and just making sure that I am doing the right thing.
2013 Fleetwood Bounder 35K
Rick and Susan
Ranger Smith
Wherever the rig is parked
Posted: 07/10/22 05:06am Link  |  Quote  |  Print  |  Notify Moderator
No . . . .Because when the tire cools off it will be low on pressure
Where we are now
Amateur Radio Operator N1JS . . . SunSDR2 Dx, Ameritron AL-80 Amp, Icom 7100
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
RB414921
Posted: 07/10/22 05:13am Link  |  Quote  |  Print  |  Notify Moderator
While driving I’ve never seen the tire pressures go down and when I pull into an RV park and set up for the night the next morning I always readjust the tire pressures back to 90 to 95 I understand what you’re saying about cool down but they normally don’t cool down while I’m driving. This is why I’m asking. Just want to know what everybody else is doing.
PButler96
Midwest
Posted: 07/10/22 05:26am Link  |  Quote  |  Print  |  Notify Moderator
You do not have to "readjust" your tire pressures every day unless you feel the need to over complicate things. Do you do that to your other vehicles?
I have a burn barrel in my yard.
RB414921
Posted: 07/10/22 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Just saying that’s what I’ve been doing with the original tires and they lasted nine years before we saw any little crack starting to form that’s why I bought the new tires so it seems like whatever I’ve been doing seems to be working any comments on that.
PButler96
Midwest
Posted: 07/10/22 05:52am Link  |  Quote  |  Print  |  Notify Moderator
Yes...........You do not have to "readjust" your tire pressures every day unless you feel the need to over complicate things. Do you do that to your other vehicles?
JRscooby
Indepmo
Posted: 07/10/22 06:00am Link  |  Quote  |  Print  |  Notify Moderator
I confess I don't know much about RV tires. But on my truck I would gauge the tires once a week. If I had to adjust 1, that tire got more attention. Before I pull out every day I would hit each with a hammer. If 1 bounced less, sounded of felt different, grab the gauge. Every stop, first thing after I got out was touch each tire and hub. If 1 was hotter than others, grab the gauge.
Pushing the valve core in on a warm tire is IMHO, a bad idea. All pressure specifications list the value cold so checking after you have been driving gives you no meaningful info. Plus there is a chance the core will not seal.
As the tire heats up, the pressure will go up. But that increase is figured in when people a whole lot smarter than I write the specs. When the tire cools, pressure will drop back to where it started.
CapriRacer
Somewhere in the US
Posted: 07/10/22 06:10am Link  |  Quote  |  Print  |  Notify Moderator
The only time you may need to adjust tire pressures within the same day is if you experience a SEVERE change in temperature - downwards (colder). And severe means more than 30°.
CapriRacer
Visit my web site: www.BarrysTireTech.com
LouLawrence
Traveling the US!
Posted: 07/10/22 06:17am Link  |  Quote  |  Print  |  Notify Moderator
I not want to sound negative but it appears you came in and asked a very good question but don't like the answers. The tire pressure stamped on the side of the tires is the COLD tire maximum rating. If you choose to inflate to max pressure when the tires are cold then you do not need to adjust the pressure down while or after driving. Yes, the pressure will be higher but that's what the tire manufacturer expects and why the pressure rating is there. The following morning the pressure will have dropped back to the cold pressure and you will be good to go the next day.
If you lower the pressure to the cold rating while the tire is hot the next day, after the tire cools, your tire pressure will be too low and you would need to reinflate before leaving.
enblethen
Moses Lake, WA
Posted: 07/10/22 07:11am Link  |  Quote  |  Print  |  Notify Moderator
First thing I would question is running max tire pressure on MH.
I would weigh the rig, get the tire inflation chart from tire manufacturer, inflate to around five pounds more than shown on chart.
I would lay odds that pressure would be lower than max pressure on sidewall.
I would not adjust tire pressure once proper inflation is achieved.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
 > Tire pressures
