Reisender
NA
Weigh the coach’s axles.
Select the proper pressure from the tire manufacturers charts for that weight
Set the pressures first thing in the morning on a cool day.
Check periodically (in the morning) to insure they are correct.
Do not adjust for temp.
RB414921
Connecticut Hill, New York
Maybe I just need to reword what I’m saying I’m saying on a long trip I’ve got a tire pressure monitoring system and when I see the pressure getting up to 110 psi do you guys continue letting it to rise or do you readjust it back down to the starting point and continue on with your trip. I was just concerned that reaching 110 psi which is the maximum PSI when you’re driving and it gets above 110 is that a good thing or a bad thing.
2013 Fleetwood Bounder 35K
Rick and Susan
Southern California :(
Your tire manufacturer doesn’t recommend lowering the tire pressure, does he/she? Tire pressure is set with cold tires. Almost all weather conditions will cause a working tire to increase its pressure.
MountainAir05
New Mexico
RB414921 wrote: Maybe I just need to reword what I’m saying I’m saying on a long trip I’ve got a tire pressure monitoring system and when I see the pressure getting up to 110 psi do you guys continue letting it to rise or do you readjust it back down to the starting point and continue on with your trip. I was just concerned that reaching 110 psi which is the maximum PSI when you’re driving and it gets above 110 is that a good thing or a bad thing.
Simple. Adjust the air pressure only when the tire is cold. Have the tire checked if you think it getting too hot. The tire can be out of balance and that will cause it to rise in pressure, along with other things.
Bruce Brown
Northern NY
That 110 psi is the cold max. The engineers have a safety factor built in.
That said, the best advice has been to weigh the MH and adjust according to the tire weight chart.
One more thing, if heat caused the rise cooling will also lower it. If you started at 90 psi and it gets to 110 while driving it won't stay there forever. If you're seeing that you might want to check your pressure senders. No one added any air while you were driving so eventually the original pressure will return.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
wolfe10
As ALL have stated, do NOT adjust pressure downward because it rises due to driving, sitting in the sun, etc!
PERIOD.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
jorbill2or
Full time
TPMS systems allow you to see real time pressures causing paranoia. Your tires have always gained pressure as you drove and you heated them up. Entirely normal. Mine have gone up 20 psi or more on the gauge. Unless you see a single tire increasing dramatically due to under inflation , friction heat from a mis adjusted brake or bearing failure , leave it alone . End of story.
Bill
opnspaces
San Diego Ca
As Bruce and a few others have stated, 110 is the max cold tire pressure. The engineers that design tires take into account the pressure increases as the tire heats up.
You do not need to bleed air out of the tires unless it is over the cold max when cold. Think cold as the rig has sat all night and you are checking first thin in the morning.
In the morning if there is a hot sun on a tire and it reads 112 and the shaded tires read 110 it's okay to leave it that way.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Ed_Gee
Central Oregon coast
To make it clear to the OP - tire pressure can easily and safely exceed maximum tire pressure ratings while driving. This is normal. Do not fret over it nor readjust!
Ed - on the Central Oregon coast
2018 Winnebago Fuse 23A
Scion xA toad
RB414921
Thanks everyone I truly appreciate all the feedback I got on this one and it makes me understand a little better about tire pressures and what not to do.
