RV.Net Open Roads Forum: Class A Motorhomes: '06' monarch House electronics not working.
 > '06' monarch House electronics not working.
RickAvery
Moorpark, Ca.
Posted: 07/10/22 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
Just returned home from a short 100 mile RV trip and when I shut the engine down none of the house electronics ie. lights, slides, water pump... would work. When I restarted the engine, they would again operate. They would also work when plugged into shore power. Both the chassis and house batteries are showing ~13vdc with the engine off and no shore connection. The house batteries are 4 Interstate 6vdc deep cycle batteries in the traditional 2s-2p configuration they are 3.5 years old and have performed flawlessly from day 1. An inspection of the electrolite levels shows all of the cells at 1/4" or greater above the plates. I have a 4 stage converter which is always plugged in when parked. Anyone have any ideas as to what the issue might be?
Thanks
-Rick
* This post was edited 08/02/22 08:14pm by RickAvery *
Bruce Brown
Northern NY
Posted: 07/10/22 07:26pm Link  |  Quote  |  Print  |  Notify Moderator
Is the 12v cutoff switch on?
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
Tom/Barb
Oak Harbor, Wa
Posted: 07/10/22 09:10pm Link  |  Quote  |  Print  |  Notify Moderator
The main battery negative cable is off, broken continuity , or
If the main disconnect switch is open, nothing woks on the alternator, or the 50 amp cable.
the engine alternator has it's own ground, as does 50 amp circuit.
RickAvery
Moorpark, Ca.
Posted: 07/10/22 10:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your replys, yes, I've checked the cut-off switch and it appears to be working properly. There is also a hard disconnect in the battery compartment which disconnects the main positive lead in which case, nothing is activated and this is also working correctly.
I will check out the negative cables in the morning.
Thanks again
-Rick
ArchHoagland
Clovis, CA, USA
Posted: 07/11/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Have you measured the voltage at the house battery terminals with a voltmeter?
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
US Gear Brakes
RickAvery
Moorpark, Ca.
Posted: 08/02/22 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you for your reply. Yes, the house batteries are at 13.0vdc.
Does anyone know where the battery boost relay is located?
Thanks
-Rick
dougrainer
Carrolton, Texas
Posted: 08/03/22 09:13am Link  |  Quote  |  Print  |  Notify Moderator
Thanks
-Rick
Monarch 2006 Gas engine? Battery boost is usually located in the Left front storage in front of the LF tire. BUT, this solenoid would NOT even remotely be your problem. The fact you have coach power when engine ON shows the boost solenoid is functioning. Page 198. Doug
https://www.monacocoach.com/resources/media/manuals/2006_Monarch_SE.pdf
