RV.Net Open Roads Forum: Tech Issues: '06' monarch house electronics not working
 > '06' monarch house electronics not working
RickAvery
Moorpark, Ca.
Posted: 07/10/22 07:25pm Link  |  Print  |  Notify Moderator
Just returned home from a short 100 mile RV trip and when I shut the engine down none of the house electronics ie. lights, slides, water pump... would work. When I restarted the engine, they would again operate. They would also work when plugged into shore power. Both the chassis and house batteries are showing ~13vdc with the engine off and no shore connection. The house batteries are 4 Interstate 6vdc deep cycle batteries in the traditional 2s-2p configuration they are 5 years old and have performed flawlessly from day 1. An inspection of the electrolite levels shows all of the cells at 1/4" or greater above the plates. I have a 4 stage converter which is always plugged in when parked. Anyone have any ideas as to what the issue might be?
Thanks
-Rick
LadyRVer
Posted: 07/10/22 07:30pm Link  |  Print  |  Notify Moderator
Is your coach battery shutoff switch in the "off" position?
Y-Guy
Tri-Cities, WA
Posted: 07/10/22 09:17pm Link  |  Print  |  Notify Moderator
Double post, closing this thread. You can reply here.
As a reminder the forum rules;"You are not allowed to post the same message in multiple forums without permission from one of the Open Roads Forum moderators."
