RV.Net Open Roads Forum: Fifth-Wheels: Using a Cpap in my AF 27-5
 > Using a Cpap in my AF 27-5
timn
oklahoma
Posted: 07/12/22 08:05pm Link  |  Quote  |  Print  |  Notify Moderator
Ok we bought a 2018 AF 27-5 and are leaving in August and I can't figure out how i am going to run my resmed Cpap while boondocking any ideas. I have several USB ports near the head board are there a adapter I can buy? Would appreciate any ideas thanks.
CA Traveler
The Western States
Posted: 07/12/22 08:31pm Link  |  Quote  |  Print  |  Notify Moderator
USB ports have limited power at 5V. Assuming the CPAP uses 12V power then just wire up a matching plug/fuse to the battery.
What are your CPAP power requirements?
2014 Grand Cherokee Overland
Bob
Trackrig
Spent the summer in Conconuly, Wa, MH now in Vanco
Posted: 07/12/22 08:55pm Link  |  Quote  |  Print  |  Notify Moderator
Your Cpap normally runs off of 110VAC. You should have 110VAC outlets in the bedroom. I'm assuming your 5th has batteries and a converter to supply 110VAC?
You can buy adapters to run them off ov 12VDC from Amazon, but there's no reason for you to do that.
And no, the USB outlets do not have enough power. Your power supply for the Cpap should use 95 to 100 watts.
Bill
Nodwell RN110 out moose hunting. 4-53 Detroit, Clark 5 spd, 40" wide tracks, 10:00x20 tires, 16,000# capacity, 22,000# weight. You know the mud is getting deep when it's coming in the doors.
B.O. Plenty
Minnesota
Posted: 07/12/22 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Go to the manufacturer of your C-Pap and see what options they offer for 12 volt power. You may need to carry a seper3te 12 volt battery to power it.
B.O.
Former Ram/Cummins owner
2015 Silverado 3500 D/A DRW
Yup I'm a fanboy!
2016 Cedar Creek 36CKTS
Durb
NW
Posted: 07/12/22 10:29pm Link  |  Quote  |  Print  |  Notify Moderator
My wife's CPAP is a Phillips Dream Station 2. Its power requirements are 12V, 6.7A. The included 120V power supply is a 12V DC transformer which she uses at times when we are on shore power. We have a Phillips supplied adapter that we plug into 12V in the trailer so it runs off the trailer's battery when needed.
When going on a houseboat trip, I will pull our 100 amp hour lithium battery and take it with us along with the trailer's convertor to charge the battery after 2 night's use. Works great and is reliable. Can recharge in 2 hours off the boat's generator.
CA Traveler
The Western States
Posted: 07/13/22 04:03am Link  |  Quote  |  Print  |  Notify Moderator
Plus for boondocking you need to understanding your energy needs, battery capacity and how the batteries will be recharged.
One option is to camp with power but leave the main CB off and see how long the batteries last. Hopefully at least one night. Do you have solar or a gen?
Bumpyroad
Virginia
Posted: 07/13/22 05:06am Link  |  Quote  |  Print  |  Notify Moderator
don't use a heated hose and use humidifier in passover mode.
bumpy
TXiceman
Bryan, TX
Posted: 07/13/22 08:03am Link  |  Quote  |  Print  |  Notify Moderator
In order to have 120 VAC power when boondocking, you will need an inverter (not converter) and a battery bank large enough to supply your needs.
You will need to add up your loads and see how much energy you will need to store in the batteries.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Southern California :(
Posted: 07/13/22 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Solar panels, Lithium batteries, MPPT controller, small PSW inverter and you’ll be set. Start with an energy survey to determine your battery needs. Be liberal too!
padredw
East Texas
Posted: 07/13/22 08:47am Link  |  Quote  |  Print  |  Notify Moderator
There are several possibilities depending on your circumstances. If you are connected to shore power you just have to find a plug convenient to your bed.
In my case I purchased the DC power adapter. I had a 12V "cigarette type" plug installed in the bedroom with direct 12V from the batteries. This allows me to bypass the inverter and save significant energy overnight. I also use this same power source when we are "hooked up" -- no reason not to.
