RV.Net Open Roads Forum: Fifth-Wheels: Using a Cpap in my AF 27-5
 > Using a Cpap in my AF 27-5
Southern California :(
Posted: 07/13/22 09:24am Link  |  Quote  |  Print  |  Notify Moderator
Modern inverters are not wasteful. Correct battery sizing makes the inverter “loss” completely manageable.
ReneeG
Meridian, Idaho
Posted: 07/13/22 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Bumpyroad wrote:
don't use a heated hose and use humidifier in passover mode.
bumpy
This.
Hubby has a CPAP. It runs off our inverter (4 bank of batteries charged by two solar panels), but we also purchased a Jackery and solar panels as a backup. The portable power station suggested by the CPAP specialist was more expensive and they said the Jackery will work. With no heat and no use of the humidifier, hubby can run almost two weeks without a charge on it. As you can see, he uses it instead of off our inverter.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
GaryUT
Northern UT
Posted: 07/13/22 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Most resmed machines run on 24 volts.
Go to cpap.com search for resmed 12v cable in the search box, find the one for your machine. You will need a 12v socket added to the trailer to use the cpap machine on 12v.
Running it off 12 volts is more efficient than using an inverter.
2019 Keystone Laredo 255SRL
2009 GMC Sierra 2500 4x4 Crew cab short bed
C Schomer
Pueblo West, Co.
Posted: 07/13/22 02:38pm Link  |  Quote  |  Print  |  Notify Moderator
I put in a receptacle for 120vac and a 12/2 12vdc circuit with a lighter receptacle for the adapter for whenever I’m boondocking. Both are on the proper CBs.
ReneeG
Meridian, Idaho
Posted: 07/13/22 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
Not more efficient, but definitely more affordable.
Posted: 07/13/22 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Jackerys and their cousins are expensive and may have their place but IMO your money is better spent on an adequate RV solar system and Lithium batteries. Also consider the recharging time a 100 water portable solar panel takes to recharge the Jackery and that you’ll need to be in camp so the Jackery doesn’t walk away.
timn
oklahoma
Posted: 07/13/22 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys I have a lot of info to process.
austinjenna
Columbus, Ohio
Posted: 07/14/22 05:41am Link  |  Quote  |  Print  |  Notify Moderator
I guess it depends on how long you will be boondocking. As others have said just dont use the heated hose and humidifier. You can also buy an external battery pack like Jackery to plug into that should be good for a few days
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
ford truck guy
Pennsylvania
Posted: 07/14/22 05:58am Link  |  Quote  |  Print  |  Notify Moderator
You could always use one of these in a pinch - - -
Portable power
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
ReneeG
Meridian, Idaho
Posted: 07/14/22 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Depending on the size of Jackery, you can go up to two weeks. We have the 1000 and do.
