RV.Net Open Roads Forum: Fifth-Wheels: Using a Cpap in my AF 27-5
 > Using a Cpap in my AF 27-5
Bumpyroad
Virginia
Posted: 07/14/22 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
I've never heard if a jackery before but they sound neat but for $600 and up they better work.
but how many amp hours do the various ones provide. Yes, they have some neat features however.
bumpy
austinjenna
Columbus, Ohio
Posted: 07/15/22 06:05am Link  |  Quote  |  Print  |  Notify Moderator
bumpy
However what? The Jackery was just used as an example, there are many others out there for cheaper and I was just giving an example of what can be used. I have used a smaller battery on my Resmed 10 that lasted 8hrs on long flights without a problem of course without the humidifier and heated tube on.
You can easily figure out the amp hours they produce.
2010 F350 CC Lariat 4x4 Short Bed
2011 Crusader 298BDS 5th Wheel
Reese 16K
dieseltruckdriver
Black Hills of SD
Posted: 07/15/22 06:08am Link  |  Quote  |  Print  |  Notify Moderator
GaryUT wrote:
Most resmed machines run on 24 volts.
Go to cpap.com search for resmed 12v cable in the search box, find the one for your machine. You will need a 12v socket added to the trailer to use the cpap machine on 12v.
Running it off 12 volts is more efficient than using an inverter.
I don't use a CPAP but I am sitting in a 2018 Arctic Fox 27-5l and they have a 12 volt plug, a 120 volt plug and USB plugs on each side of the bed making it pretty easy to do what Gary suggested.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
ReneeG
Meridian, Idaho
Posted: 07/15/22 07:16am Link  |  Quote  |  Print  |  Notify Moderator
Nice!
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
timn
oklahoma
Posted: 07/17/22 02:08am Link  |  Quote  |  Print  |  Notify Moderator
That's weird on my 2018 27-5 I don't have a 12volt beside my bed wished I did.
Johnnybgood
Illinois
Posted: 07/17/22 08:18am Link  |  Quote  |  Print  |  Notify Moderator
I built a 24v battery bank and run a Samlex 2200 watt all in one inverter/ charger /transfer switch. It is wired to the main board so the receptacles for my wife’s cpap are on as well as for the fridge. The transfer from shore power to battery is so fast the tv’s and computer don’t even flicker. The fridge was upgraded to a compressor fridge. Now our food stays cold and we don’t worry about having to get a campground. We still do campgrounds as my wife is just happier if we do.
philh
Belleville MI
Posted: 07/20/22 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
I mounted an inverter in the battery box and put a 50a receptacle on the front of the trailer, wired to the transfer box. 2200w inverter hard wired to 50a plug. I pull the plug out of the battery box, plug it in, and I have 120v throughout the 27-5L
PhilipB
MO
Posted: 07/20/22 03:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have a small Jackery that I paid around $2-$300. Works fine. Recharge in the truck during the day as we drive.
2015 Ram 2500
2013 Raptor 310TS
Njmurvin
Simi Valley
Posted: 07/22/22 03:54pm Link  |  Quote  |  Print  |  Notify Moderator
We just went a week boondocking in the Sierras. I could have simply plugged the AC adapter into an outlet using the inverter, but I thought I would try to be more efficient. So, I bought the 12v adapter for my wife's Resmed off Amazon and an extension cable for the cigarette plug. I have 2 12v marine batteries from Costco, a 135 watt solar panel on the roof and a portable 100 watt panel I can move around to optimize solar exposure.
We ran the humidifier on low (no heated hose). Batteries never got below 86 percent or so by morning after running the CPAP all night. We had a relatively small number of clouds that week and the batteries were replenished by the sun by lunch time each day. I had my generator with me but never had to fire it up.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
Bionic Man
Colorado
Posted: 07/22/22 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I use this when we don't have power. Without the humidifier I can go 4-5 days without charging. 2 days with the humidifier.
This
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
