RV.Net Open Roads Forum: Tech Issues: Gray Tank Smell (Seriously annoying)
 > Gray Tank Smell (Seriously annoying)
Page of 5
Posted: 07/15/22 05:46am Link  |  Quote  |  Print  |  Notify Moderator
Don't forget to let us know the cause when you find it. Inquiring minds what to know.
2013 KZ Durango 2857
Wulrich
Posted: 07/15/22 05:53am Link  |  Quote  |  Print  |  Notify Moderator
I definitely will!
midnightsadie
ohio
Posted: 07/15/22 05:59am Link  |  Quote  |  Print  |  Notify Moderator
had a smell one time was the seal around the commode. the rubber one at the slide gate.
jjrbus
FT Myers FL
Posted: 07/15/22 07:08am Link  |  Quote  |  Print  |  Notify Moderator
Tough one!! If all else fails a plumbing smoke test can be performed, either diy or professionally. Google RV plumbing smoke test. I had to strip a wall to repair a screw hole in the vent pipe.
opnspaces
San Diego Ca
Posted: 07/15/22 09:00am Link  |  Quote  |  Print  |  Notify Moderator
Quick warning on the dry ice. It can give you frost bite if you touch it with bare hands. Wear some kind of gloves thicker than surgical gloves or use a pair of tongs to pick up the ice pieces.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Lantley
Ellicott City, Maryland
Posted: 07/15/22 09:36am Link  |  Quote  |  Print  |  Notify Moderator
JimK-NY wrote:
Do I understand there are no odors unless the A/C is running? If that is the case, I don't see any connection with the grey water. I would check the A/C. Maybe a dead critter in the unit. As mentioned the A/C does not pull any outside air so the offending item would be inside in the A/C or ductwork if there is any.
The AC does not pull outside air but it does circulate interior air if the break or smell is present in the roof line or attic area it will drift into the AC duct system which is not 100% air tight.
Once the smell enters the AC duct the AC system blows the foul air into the interior of the RV where it becomes a noticable bad smell.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Itinerant1
Itinerant
Posted: 07/15/22 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Why I mentioned to check vent pipes at roof line if everything else isn't curing the issue, can't hurt to check.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,400+ partial cycles.
pismopete
central cal
Posted: 07/15/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Had the same problem with my two grey tanks. Bought a Flush King and back washed both tanks. Problem gone. Now I back flush every time I dump.
dougrainer
Carrolton, Texas
Posted: 07/15/22 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
1. If you flush the GRAY tank and then put sweet smelling stuff in it. You should get sweet smelling odors. ALWAYS. I use Pine sol at our shop
2. You don't even mention the Black tank. The usual suspect in your case IS the Gray tank, but since you have completely flushed the Gray and use sweet smellers, then I would suspect the black tank
3. Is your RV Washer/Dryer prepped? If so, there is usually NO water in the drain tube P trap which stops gray odors. Even if you have a W/D, if rarely used the water drains or evaporates from that P trap
4. You are positive your Battery is not boiled dry?
5. Last, is not an easy thing to do. Your black tank toilet down pipe may not be attached to the top of the black tank and those odors WILL migrate up. Your GRAY tank may have the same problem, either one of the down pipes or even the vent pipe may not be attached securely into the tank. Also the Black vent pipe may also not be attached.
6. The roof vent covers for the tank vent pipes, the pipes may not protrude up into those caps. check and see if the ABS comes up all the way. Another EXTREME cause is the 1.5 ABS vent pipe is indeed ALL THE WAY up and the cap on the top on the vent pushing against the pipe effectively not allowing the tank to vent.
7. RVIA code dictates that correctly installed Tank systems must hold water when on the gray water you overfill until water comes up and the lowest point which is usually the shower or tub drain Black water must come up the toilet down pipe just below the ball valve and hold for 10 to 20 minutes. Doing this test will tell you if the connections on top the tanks are correctly sealed. IF you decide to do this test FLUSH/FLUSH/FLUSH the tanks.
8. USE Pinesol for smell tests.
9. Hopefully you do not have a dead critter someplace. Doug
red31
Dallas
Posted: 07/15/22 05:56pm Link  |  Quote  |  Print  |  Notify Moderator
What is the source of the water from the faucet?
Cabin with well water has rotten egg smelling water, anaerobic bacteria grow in the pressure tank.
Page of 5
