RV.Net Open Roads Forum: Tech Issues: Gray Tank Smell (Seriously annoying)
 > Gray Tank Smell (Seriously annoying)
Page of 5
Posted: 07/14/22 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Wulrich wrote:
2oldman wrote:
Is you kitchen in a slide?
It is not in a slide, it’s in the center
I'm thinking the AC is above the sink and the AC is sucking the water smell into the ductwork
2013 KZ Durango 2857
2oldman
NM
Posted: 07/14/22 08:38am Link  |  Quote  |  Print  |  Notify Moderator
Okay, mine is, and what happened to me is after 20 years of sliding, the flexible tubing carrying sink water came loose and allowed water to drain inside. I only found it when water was dripping onto the ground through the frame.
MitchF150
Puyallup, WA
Posted: 07/14/22 09:01am Link  |  Quote  |  Print  |  Notify Moderator
Have your tried running the sink faucets into a tub only? This would eliminate the holding tank in the equation. Then, if you smell the same thing, then it's your water source.. If you don't smell anything, then it's the holding tank.
Not sure what the solution would be for either issue, but at least it might help narrow down the guessing?
Good luck! Mitch
valhalla360
No paticular place.
Posted: 07/14/22 09:05am Link  |  Quote  |  Print  |  Notify Moderator
The air/con doesn't pull air from outside to inside and should have no other connection to the plumbing system, so the rooftop vent is unlikely to be a factor.
The air/con circulates air being picked up from the main panel in the ceiling pumping it thru the vents. Best guess is the odor is being released from the sink area right below the air/con unit and it is pulling that smelly air into the system to distribute it.
The air/con is most likely a symptom but not a cause.
Try using the faucet to put water into a bowl without any going down the drain. Is there a smell?
- If yes, it's likely in the fresh water supply system.
If not, dump the bowl down the sink. If that causes the smell, it's likely in the drain system.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
agesilaus
North Florida
Posted: 07/14/22 09:22am Link  |  Quote  |  Print  |  Notify Moderator
Our fix: one small quart bottle of chlorine bleach in the tank. Pour some down every drain. Leave in the tank plus some water, a quarter of more full, overnight. Drain. Good for a couple of months anyway.
I suspect bacterial film forms on the walls and that film is very tough to remove.
We have one of those directional vane caps that is supposed to turn the vent top away from the wind, did not seem to be effective. Noticed the smell increased when ac on, suspected ac inlet is ingesting air from the tank vent. But as pointed out above that is not the case.
Arctic Fox 25Y Travel Trailer
2018 RAM 2500 6.7L 4WD shortbed
Straightline dual cam hitch
Superbumper
Southern California :(
Posted: 07/14/22 09:35am Link  |  Quote  |  Print  |  Notify Moderator
"Sanitize your whole water system with bleach. It may be microbes in your water lines."
Bleach is your friend. Use it liberally, let it sit in the fresh water system, run it into the waste tanks, let it sit and then rinse the fresh water system.
TechWriter
Part-Timing Again
Posted: 07/14/22 10:32am Link  |  Quote  |  Print  |  Notify Moderator
x 2
2004 - 2010 Part Timer (35’ 2004 National RV Sea Breeze 8341 - Workhorse)
2010 - 2021 Full Timer (41’ 2001 Newmar Mountain Aire 4095 DP - Cummins)
2021 - ??? Part Timer (31’ 2001 National RV Sea View 8311 - Ford)
www.rvSeniorMoments.com
DISH TV for RVs
Itinerant1
Itinerant
Posted: 07/14/22 10:43am Link  |  Quote  |  Print  |  Notify Moderator
If your black or grey roof vent pipes coming from the holding tanks aren't tall enough to protrude through the roof into the vent covers you might be getting some smell in between the roof and ceiling.
I had a stink occasionally and couldn't figure it out like you till I finally pulled the vents covers off, grey pipe was 1" shorter than the roof line. I added an adapter on problem solved.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,237+ partial cycles.
bukhrn
Lanexa, Va
Posted: 07/14/22 11:56am Link  |  Quote  |  Print  |  Notify Moderator
You mentioned that you get the smell with the AC running, do you get the same smell from the sink area Without the AC on?
2007 Forester 2941DS
2014 Ford Focus
Dave in TN
Middle Tennessee
Posted: 07/14/22 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
This product worked for me when we encountered grey tank odor issues. Of course if your problem isn't tank related this wouldn't help.
https://www.amazon.com/Camco-40597-Black-Cyclone-Plumbing/dp/B00SQ1K19A?th=1
Dave & Christy
5 Awesome Girls (25,23,21, 15 and 13)
Sold the Winnebago
2012 Ford Flex LTD FWD Toad
Dreaming of another RV...some day
Page of 5
