Truck is a 2006 Dodge Heavy 2500 with the Cummins diesel.
Thanks.
Long bed Pullrite Super Fifth.
Short bed Pullrite Super Glide.
For both Pullrite under bed mount gives you a clean bed when hitch is out.
C.B.
Agreed. For your truck there are not that many clean bed options. I had a 2008 Dodge Ram 2500 with the short bed and a Pullrite Superglide. At the end of the year I pulled 8 pins and lifted the hitch out of the bed. It is easiest if you have a hoist as the hitch is not light. If no hoist it may cost you a beer for your helper. Not that heavy for two people.
Lippert will not warranty any frame damage from any single point hitch other than the Reese Goosebox. Example: Andersen, PullRite, etc.
I went from a PullRite 2600 to a Reese Goosebox and it is a great ride with zero bucking.
Since you don't have a factory gooseneck ball you will need to get one installed. Your choice but, be sure it is rated high enough for any 5th you may get in the future. B&W Turnover ball is popular.
EDIT ADD: Lippert will not warranty any single point (gooseneck ball) but the Reese Goosebox because they own Reese.
edited 07/17/22 02:55pm by TxGearhead *
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
