RV.Net Open Roads Forum: Truck Campers: Sealing my TC's EPDM Roof
 > Sealing my TC's EPDM Roof
sonuvabug
Mid-West Ontario, Canada
Posted: 07/18/22 07:25am Link  |  Quote  |  Print  |  Notify Moderator
I tried searching for a thread using every combination of words I could think of with no real luck.
I want to seal my EPDM roof with the best product based on people's experiences. I keep my 2007 TC's roof clean and it is in good shape for it's age but I feel it's time to put a protective coat on it.
I've spent hours on YouTube reviewing clips spouting the merits of all of the usual suspects (Dicor 2-part system, Flex Seal, Henry Silicone RV roof sealant, others etc.) More confused now than ever.
Any recommendations based on first hand experience/ or can you direct me to a thread where this has been already thoroughly covered. Thanks.
2007 Adventurer 90fws Truck Camper
2001 FORD F250 SuperCab; 8' box; 4x4, 7.3l diesel, rear Sumo Springs
ICamel
Oregon
Posted: 07/18/22 11:59am Link  |  Quote  |  Print  |  Notify Moderator
https://www.rv.net/forum/index.cfm/fusea........hread/tid/30345914/srt/pa/pging/1/page/1
ICamel
2017 Arctic Fox 992
2005 Ford F350 Lariat SuperDuty CrewCab 4x4 + 6 Speed Manual + 19.5" Tires + LoadLifter 5000 Rear Air Bags
2005 16' River Wild Drift Boat
Honda EU2000i
Trophytrout FlyFisherman
sonuvabug
Posted: 07/19/22 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the link but not really the answer to the questiohn I'm asking. Let me try it a different way.
I have a 15 year old roof that is in good shape. Once clenaup up(annually), it looks very good. I see no "black" spots bleeding through.
I'd like to seal the roof with a good product designed to help protect it and hopefully, extend it's life.
What are the better products out there, for this purpose, that people have used with success.
mkirsch
Rochester, NY
Posted: 07/19/22 08:44am Link  |  Quote  |  Print  |  Notify Moderator
Likely reason why you can't find the answer is because the question has never been asked.
I believe the whole point of the EPDM roof is, that you don't have to be constantly re-coating it with "sealants." It's meant to be relatively maintenance free.
The big problem with putting any coating on is, there's no way to get it off. Only way to fix it is to peel the EPDM up and replace with new.
I've seen rumors that Flex Seal does not last, degrades quickly in the sun.
notsobigjoe
southeast
Posted: 07/19/22 09:18am Link  |  Quote  |  Print  |  Notify Moderator
Some info.
https://www.epdmcoatings.com/index.php
Reapplying it here.
https://www.epdmcoatings.com/application-roof-leaks-repair.php
Joe417
AL
Posted: 07/19/22 02:55pm Link  |  Quote  |  Print  |  Notify Moderator
This is just my experience, we have a 21 year old 5th W. with the original EPDM and no coatings added. I keep it under a roof when not in use and wash it and put a rubber roof conditioner on it every other year. It is in very good shape for it's age.
Our 2005 TC had the Dicor coating on it when I bought it in 2012. It has held up very well.
After, I am guessing about 50K miles, it had a few scratches in the coating, not the EPDM, so I recoated it last year.
I have replaced the EPDM on 2 of our previous campers and I think that one would have been an excellent candidate for the coating rather than replacing the rubber. I had no experience with it at the time.
I will use the coating in the future as long as there is no damage to the decking.
You do need to clean it well and use the Dicor cleaner/activator so that is sticks well. 1 gallon was enough to put 1 coat on our TC. If it were the first coat I would have put 2.
The most time consuming part about using the Dicor was putting plastic over the sides to keep the cleaner/activator off. I don't know if it will actually damage the fiberglass but I didn't want to take the chance. It was in the spring but was too hot and the tape kept coming loose. I think it took me about 6 hours as I had to keep climbing up and down from the roof and I had no helper.
Good luck.
Joe & Evelyn
notsobigjoe
southeast
Posted: 07/19/22 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck.
Thanks for the info and input Joe, I never knew any of this dicor treatment existed but I am curious to try it on my 1181. Thanks again, you always learn something new on this forum.
Joe
https://www.amazon.com/s?k=dicor+EPDM+coating&crid=26MT6BQTYW5GR&sprefix=dicor+epdm+coating%2Caps%2C88&ref=nb_sb_noss_2
sonuvabug
Posted: 07/21/22 10:37am Link  |  Quote  |  Print  |  Notify Moderator
mkirsch wrote:
... snipped ... Likely reason why you can't find the answer is because the question has never been asked.
This makes perfect sense although YouTube has many "how-to" videos so I thought perhaps I am missing out on something important that everyone does and is something for me to consider doing.
Confused as I became, I called the FraserwayRV Cookstown ON dealer (designated Adventurer TC dealer) where we bought our new-to-us 2007 TC unit in 2014 and here's what the Service Writer told me.
The EPDM roof should last the lifetime of our TC if taken care of. Of course "lifetime" is subject to interpretation. He said the most important things are to keep it clean of organic debris, environmental sooting and heavy dirt, inspect it regularly and, stay on top of maintenance (like lap sealing around vents, re-caulking seams etc. as needed and performing spot repairs i.e. repairing rips, punctures etc. as discovered).
I told him we have one small (1/2 sq. ft.) corner area where the top EDPM layer seems to have come loose from the underneath decking. There are no tears, holes or separation evident on the sides of this "looseness".
He said not to worry as this is not unusual and likely due to less glue used in that specific spot. He added it was not uncommon for them to see larger rubber roof sections on RV's being loose because of a lack of glue and his advice is to leave it alone unless it is compromised and causing problems like a leak.
For ours, he also advised if the rubber fabric was otherwise whole, undamaged and not deteriorating, to also leave the loose area alone. For all I know it could have been like this for years and I just noticed it recently.
Thanks All for responding and I hope this additional information is also useful.
ticki2
NH
Posted: 07/21/22 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have no experience with the product but it looked interesting . I would also try calling a commercial roofing co and ask what they recommend , EPDM is used on all kinds of commercial buildings .https://www.rvroofmagic.com/store/
'68 Avion C-11
'02 GMC DRW D/A flatbed
wanderingbob
monticeeo, fla
Posted: 07/21/22 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
HENGS
