RV.Net Open Roads Forum: Towing: Towing with older vehicle
Search only in Towing
Open Roads Forum  >  Towing
 > Towing with older vehicle
Grg419
Midwest
Posted: 07/18/22 07:12pm Link  |  Quote  |  Print  |  Notify Moderator
I'm thinking about towing a small hatchback under 2000 lbs with an 06 roadtrek. The roadtrek/chev express is a V8 rated up to 10,000 lbs towing has under 60k mileage but is there legitimate concern about the stress to the frame?
LadyRVer
Posted: 07/18/22 07:41pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 2003 Pleasure Way, hitch rated for 10,000#. I wouldn't have hesitated in the least bit to tow a lightweight car.
ktmrfs
Portland, Oregon
Posted: 07/18/22 08:32pm Link  |  Quote  |  Print  |  Notify Moderator
I had a 87 chevy van with towing option and towed a 4500 lb trailer all over the west. sold it with 180K miles, still running strong. And that V-8 was only around 165hp or so, hills were 2nd gear wound out.
you should have no issues.
2011 Keystone Outback 295RE
enblethen
Moses Lake, WA
Posted: 07/19/22 08:15am Link  |  Quote  |  Print  |  Notify Moderator
Only concern on frame is whether it has been extended by RV manufacturer. Look at the frame where the trailer hitch connects. Some have butt welded frame extensions that may need reenforced. Common on earlier MHs.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
mkirsch
Rochester, NY
Posted: 07/19/22 08:53am Link  |  Quote  |  Print  |  Notify Moderator
Where are you getting the rating from? Roadtrek, or Chevy?
If Roadtrek, then whatever they've done to the frame, if anything, is adequate to tow the rated amount.
In that case 2000 <<<<<<<<<<<<<< 10000, so there is no concern. The workmanship would have to be awfully poor, or the van driven exclusively in the salt belt during the winter, for there to be any sort of concern towing a 2000lb trailer.
valhalla360
No paticular place.
Posted: 07/19/22 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Not that it's likely to be a problem with a 10k tow rating but what hatchback do you have that is under 2000lb?
Roadtrek is basically just a full size van. Before 4 door pickups became all the rage, full size vans were the tow vehicle of choice for families.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Posted: 07/19/22 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Is the frame rusted out or something? Maybe I missed part of the question?
