RV.Net Open Roads Forum: Towing: cross winds?
Search only in Towing
Open Roads Forum  >  Towing
 > cross winds?
RICK-ards Red
Ontario
Posted: 07/19/22 11:15am Link  |  Quote  |  Print  |  Notify Moderator
I have a Husky Friction Sway Control and while driving in a cross wind (not strong enough to stop) is it better to tighten the friction bar or loosen it to try to reduce the effect of the wind on the driving vehicle?
thanks
2017 Coachman Catalina 25RKS
2015 GMC Sierra 1500 - Kodiak edition
nickthehunter
Southgate, MI
Posted: 07/19/22 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
I don’t change mine for wind.
Samsonsworld
West Texas
Posted: 07/19/22 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Tighten
valhalla360
No paticular place.
Posted: 07/19/22 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
In theory tighter would be better as it will provide more resistance from sway but that assumes it's within the ability of the device. Locking it down super tight may cause other issues.
Far better is to have a rig that doesn't sway and that's mostly about getting a decent amount of hitch weight (ideally around 15%) on a truck that can handle it.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Southern California :(
Posted: 07/19/22 03:56pm Link  |  Quote  |  Print  |  Notify Moderator
Tongue weight is the key IMO. What percent of TW do you have?
Microlite Mike
NW Washington State
Posted: 07/19/22 07:40pm Link  |  Quote  |  Print  |  Notify Moderator
I just adjust my friction sway control for regular driving and dealing with passing trucks, etc.
When side/crossing wind becomes an issue the best measure is to slow down. This gives you more time to react and adjust when hit with a gust than at higher speeds.
"Knowledge is realizing that the street is one-way, wisdom is looking both directions anyway."
~ Albert Einstein
mkirsch
Rochester, NY
Posted: 07/20/22 05:18am Link  |  Quote  |  Print  |  Notify Moderator
I thought friction sway controls were not to be "adjusted." They are either on or off. Crank them down or release them, no in between
BarneyS
S.E. Lower Michigan
Posted: 07/20/22 08:52am Link  |  Quote  |  Print  |  Notify Moderator
You are partially correct. The friction controls handle is supposed to be used as an On/off device and not to control how much fricion is generated by the control. You are supposed to tighten it as far as it goes every time so you can be consistent in your settings.
The adjustment for the control is done with the small bolt located below the long handle. This should be turned in 1/4 turn adjustments until the desired control is achieved. Of course, this is usually a one time event and you do not change it for different conditions.
About the only time you would want to change the friction setting with this bolt is when you tow a different trailer that may be lighter or heavier than the one you initially adjusted it for.
About the only time you would change the handle location is during slippery conditions in which case you may want to loosen it all the way (snow,ice,rain,sand,etc). This is done so the truck will turn as intended and not just try to stay straight in a turn. I say "may" because in the many years that I used one, I never loosened it at all even when towing in snow. Never had a problem doing that but admit it is contrary to the printed instructions.
Barney
Not towing now.
BarneyS
S.E. Lower Michigan
Posted: 07/21/22 06:39am Link  |  Quote  |  Print  |  Notify Moderator
His question was about towing in a crosswind. That would affect every trailer - even those with perfect tongue weight percentage.
Barney
* This post was edited 07/21/22 06:46am by BarneyS *
valhalla360
No paticular place.
Posted: 07/21/22 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Barney
No, if the trailer behaves well, a crosswind may push the whole rig to the side but will not induce sway in most conditions (yes, in extremes all bets are off).
If the hitch weight is low, a cross wind may induce sway (or the driver jerking the wheel in surprise may cause it).
A couple years back we got caught in Wyoming in 40mph crosswind with 60mph gusts (at least that's what the signs said). A couple times we found ourselves 6ft onto the shoulder with a gust only doing 40-45mph but no sway (semis were having similar issues). Of course, we called it a day and got out fresh undies at the next exit.
If the setup is marginal, a sway control bar helps compensate for a light hitch weight but much better is to have a rig that handles it well because if things actually get bad, the sway bar will reach a point where it won't be able to compensate.
 > cross winds?
