RV.Net Open Roads Forum: Tech Issues: Inverter ?
 > Inverter ?
wanderingbob
monticeeo, fla
Posted: 07/20/22 12:49pm Link  |  Quote  |  Print  |  Notify Moderator
Assuming that I have the battery power would a 3,000 watt inverter run a rooftop 13,500 air for an hour or so ? I now have 4 six volts hooked up as 12 volts . I would only need air for an hour or so each day . Nothing else on batteries except normal pumps and lites .
BB_TX
McKinney, Texas
Posted: 07/20/22 01:29pm Link  |  Quote  |  Print  |  Notify Moderator
13.5k A/C draws around 13 amps of 120 vac. That is around 130 amps of 12 vdc. Don’t know what starting amps is but a soft start would help.
Gdetrailer
PA
Posted: 07/20/22 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Go with a 3000 watt generator, otherwise you are barking up an expensive tree.
High wattage loads like A/C while can be done via large battery banks for short periods of time, it draws the batteries down at a much faster rate than small low amperage loads. Basically depleting the charge at a much faster rate. It is also hard on the batteries and you need to recharge the batteries very quickly if you hope to have long life from them.
As noted, 13.5K A/C can draw 13A at 120V which is 1560W, but that does not take into account the startup surge which can be as much as 25A at 120V or about 3,000W.. Most cheapo inverters do not have enough surge capability in time they are able to provide the surge power to handle A/C compressor startup..
That 25A at 120V roughly translates to 250A or more at 12V..
Generator is the correct tool for the job.
Southern California :(
Posted: 07/20/22 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
Running an RV A/C with an inverter and batteries just isn’t practical now IMO.
wanderingbob
monticeeo, fla
Posted: 07/20/22 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
I got the generator , I was just curious ! Thanks !
time2roll
Posted: 07/20/22 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
Yes if the 4x GC2 are fully charged they should drive the A/C for an hour. But not much more. The 1 hour discharge rate will reduce capacity close to 50%. (Peukert effect)
3000w inverter should have no issues. My 2000w will start and run my 16yo Dometic 13.5 BTU A/C same as utility power. Mine will draw 120-130 amps running the A/C.
675w Solar pictures back up
3 tons
NV.
Posted: 07/20/22 03:32pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, X 2
3 tons
Posted: 07/20/22 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
As someone said 13.5k A/C draws around 13 amps of 120 vac. That is around 130 amps of 12 vdc. Don’t know what starting amps is but a soft start would help. Strangly a 15K AC.. about the same amount (I was surprised when I upgraded my Carrier (That's what I had 13.5K and that's what it drew 13.5 amps) to a 15K (Carrier is out of the business so it was a different brand) it also drew 13.5 Running bit more on the start)
4 GC-2s is about 440 Amp hours at the 20 hour rate about 200 usable by the inverter (I suspect it has a cut off).. One hour would be about 135 amp-hours But wait there another factor Peukert's law Basically it says "The faster you draw down a rechargable battery.. The Faster still it runs down"
That is at that discharge rate you wont get anywhere near the full capacity of the battery. And no.. I do not know how bad it will be.
theoldwizard1
SE MI
Posted: 07/20/22 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
Better get a Micro-Air EasyStart !
2oldman
NM
Posted: 07/20/22 06:40pm Link  |  Quote  |  Print  |  Notify Moderator
Don't think you need one with an inverter.
An hour?.. that may be pushing it a bit. LA batteries, especially just 4, will likely lose too much voltage over that amount of time and shut down the inverter. Plus, wires and connectors - and even the batteries - are going to get hot if not sized exactly and clean and fresh. Plus you need them to be at nearly 100% charge. I used a lot of high-wattage appliances with 4 batteries, but I found 6 to work much better. It's just a whole lotta weight.
I think an hour may be just too much.. but hey, prove me wrong!
 > Inverter ?
