WildCloud
Idaho and beyond
Hello All. I have a Magnetek 6325 converter in my rig that does not work. I removed the converter and found a broken electrical part. I can’t read the part (ID)number on the broken part. Can anyone help me figure out what it is so I can purchase a new one?
![[image]](https://drive.google.com/file/d/1Q6PT3xhTaYRccW4gL6QhRG7O0mJV8U-c/view?usp=sharing)
![[image]](https://drive.google.com/file/d/1TYmSGzcSLUSEN8w2enz2Yl731ZGqGnNV/view?usp=sharing)
Hopefully, i uploaded those pictures correctly. Thanks for the help!
WildCloud
Idaho and beyond
I’ll try again.
WildCloud
Idaho and beyond
Pic number 2
WildCloud
Idaho and beyond
I have no idea why i can’t properly upload my photos of the part.
enblethen
Moses Lake, WA
New members cannot most photos for after some posts.
Part looks like a ceramic resistor.
You would be better off with replacing converter completely. You would get better battery charging and performace.
Try contacting Bestconverter.com for a good replacement. Maybe one of these Converter lower section
photo 1
Photo 2
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Seattle Steve
Tucson
I also would just replace that ancient unit.
The manual does have part numbers and descriptions if you want to repair
Joe417
AL
That is a high wattage resistor. It is about 2 to 2.5 inches long so I will guess in the 25 to 50 watt range. The value/part number is probably on the back side or bottom. You'll have to drill out the rivet to verify.
That resistor is probably $10 to $15 dollars.
Now for the opinion....
I can't speak for newer Magnetek converters, but I have worked on several old Magnetek converters, 2004 and older, and I would not fix it. The output was not filtered and controlled like todays converters.
I suggest replacing with a modern Progressive Dynamics multi-stage or another brand of equivalent output. They are microprocessor controlled and have multi-stage charging which is much better on the battery.
Look on line, I picked up one about 2 years ago for $60. Currently I'm seeing 100 - 150 on ebay.
Good luck.
Joe & Evelyn
enblethen
Moses Lake, WA
Photo 2 shows value as .3 ohms
StirCrazy
Kamloops, BC, Canada
oh man take that battery killer to the dump and replace the whole power centre. I had one like that in my camper when I bought it and it came out and a proper PD 4000 series went in to replace it. fairly strait forward, since you took it out you have a clue. I took the opertunity to upgrade my battery cables and such while I was at it as I also moved the battery location.
I went with this one https://www.progressivedyn.com/pd4000-series/ as it was close to the original size and I only had to make the opening 1" bigger.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
pianotuna
Regina, SK, Canada
Replace.
Regards, Don
