enblethen
Moses Lake, WA
This is a Direct replacement for the lower section of the converter along with a new 12-volt distribution center.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Unless preserving a rare historic vehicle.... get a replacement converter.
PD4635
675w Solar pictures back up
steveh27
Grosse Pointe Woods, MI
time2roll wrote: Unless preserving a rare historic vehicle.... get a replacement converter.
PD4635
That's the one I replaced my old Magnatek with and am glad I did.
PD4635
I agree with Time2Roll the PD is a better converter
I also agree that Part looks like a ceramic resistor.
Though why the would need one of 0.3 ohms I do not know.. 0.003 perhps but 0.3 is a tad high (at 60 amps that's over 1,000 watts. drop a zero from the watts for every zero you put in front of the 3)
StirCrazy
Kamloops, BC, Canada
PD4635
the problem with that is it doent have the distrabution side (unless it just isn't showing it. the old paralax ones are not filtered dc and in my case only had two 12V circuts with old glass fuses and one 120V with a resettable push button for a breaker. by using a 4000 series power centre you get up to 10 or 12 , 12v circuts and up to 4 120V. I only used two of the 4 so far but if the wife decides she wants a microwave i can add that.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
time2roll
StirCrazy wrote: time2roll wrote: Unless preserving a rare historic vehicle.... get a replacement converter.
PD4635
the problem with that is it doent have the distrabution side (unless it just isn't showing it. the old paralax ones are not filtered dc and in my case only had two 12V circuts with old glass fuses and one 120V with a resettable push button for a breaker. by using a 4000 series power centre you get up to 10 or 12 , 12v circuts and up to 4 120V. I only used two of the 4 so far but if the wife decides she wants a microwave i can add that. The link has a new 12v distribution fuse card shown.
If the OP wants to expand 120v distribution we can address that separately as needed.
PD4635
The 4600 series is designed to replace the Electronics on older Converters like the Magnetek or less reliable ones like the WFCOs.
Now the original Magnatek has two outputs.. One rad unfiltered rectivied AC and one that goes to the battery (Also unfliltered but the battery is a filter) with the 4600 you simply bridge those (Blue and red) leads (tie them together) since it's a filtered DC out Way way way way way better.
StirCrazy
wa8yxm wrote: StirCrazy wrote: time2roll wrote: Unless preserving a rare historic vehicle.... get a replacement converter.
PD4635
ya for mine, it would have been a lot more work to get that to work then just replacing the whole thing. I also gained the bonus of being able to take all the 12V accessories and give them there own fuse instead of the fridge, furnace, all the lights, water pump and such being all on two outputs. but if there is a 12V distrabution panel that would work for that also. with the 120V side I was able to have the charger on a breaker also so I can turn it off if I decide to run an inverter, I kinda made the system expansion ready, but I could see if you wanted to maintain that "look" then you wat somthing that hids behind the sceen.
