PButler96
Midwest
I just pulled everything back there apart at the campground on my 2500, I couldn't find a zerk, do I need to pack some grease in by hand after all this oil stops dripping out? Sounds like a messy proposition lol.
I have a burn barrel in my yard.
enblethen
Moses Lake, WA
As Grit Dog said earlier, DANA 80s are lubricated from the differential.
Are you sure it is a DANA 80 and not a DANA 60?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Huntindog
Phoenix AZ
It is not just full floating rearends that use the differential oil for the bearings. Semi floaters do as well. In fact I have never heard of a conventional rearend that uses grease for them...FWIW, I have totally rebuilt axles incuding setting up new Ring and Pinion gears.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1860watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
RLS7201
Huntindog wrote: It is not just full floating rearends that use the differential oil for the bearings. Semi floaters do as well. In fact I have never heard of a conventional rearend that uses grease for them...FWIW, I have totally rebuilt axles incuding setting up new Ring and Pinion gears.
Now your showing your age.........About 1964 the auto/light truck manufactures switched to axle bearings that lubed with def. grease. Before that the press on axle bearings has grease in them with seals on both sides. MOPAR used tapered axle bearings pack with grease and seals on both sides of the bearings. The right side axle bearing had an adjustment to set the end play.
Richard
95 Bounder 32H F53
460/528 stroker
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
time2roll
RLS7201 wrote: Now your showing your age.........About 1964 the auto/light truck manufactures switched to axle bearings that lubed with def. grease. Before that the press on axle bearings has grease in them with seals on both sides. MOPAR used tapered axle bearings pack with grease and seals on both sides of the bearings. The right side axle bearing had an adjustment to set the end play.
Richard My family had both a 1965 Coronet and Belvedere that had this set up. What a pain and nobody seemed to know how to work on it by the late 1980's.
To the OP.... yes check the fluid level. If it is over 150k miles or 20+ years it would be OK to just change the fluid.
675w Solar pictures back up
Missionstreet
PA
To the best of my knowledge , this is a full floating axle that is oil bathed. With an idea of some average temps I would gain peace of mind until I am able to pull the cover + shafts and inspect the hub bearings along with diff.
Huntindog
Phoenix AZ
time2roll wrote: RLS7201 wrote: Now your showing your age.........About 1964 the auto/light truck manufactures switched to axle bearings that lubed with def. grease. Before that the press on axle bearings has grease in them with seals on both sides. MOPAR used tapered axle bearings pack with grease and seals on both sides of the bearings. The right side axle bearing had an adjustment to set the end play.
You are correct. I have never worked on anything that old. I try not to make definative statements on these sort of things as no matter how rare it may be, someone on the internet will bring it up.
rjstractor
Maple Valley, WA
enblethen wrote: As Grit Dog said earlier, DANA 80s are lubricated from the differential.
A Dana 60 rated to carry 9450 lbs?
Missionstreet
PA
I have a dana 80.
1999 F53
enblethen
Moses Lake, WA
I recently had work done on my Chev P-30 including rear axle bearings and seals. Ordered parts as shown for Spicer Dana 80. None of the parts were correct as the axles were different then shown for Dana 80. My axles did not have flange on end but a sprocket. Seals were larger on mine. Spindles style were different. Bearings were flat and not tapered.
