RV.Net Open Roads Forum: Fifth-Wheels: Anderson Camper Levelers
 > Anderson Camper Levelers
Esacnj
NJ
Posted: 07/23/22 08:56am Link  |  Quote  |  Print  |  Notify Moderator
Do they work?
CA Traveler
The Western States
Posted: 07/23/22 10:16am Link  |  Quote  |  Print  |  Notify Moderator
Yes
2014 Grand Cherokee Overland
Bob
spoon059
Just north of D.C.
Posted: 07/23/22 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I LOVE mine. Find the low side, put out the Andersons and slowly drive until you are perfectly level.
2015 Ram CTD
2015 Jayco 29QBS
fj12ryder
Platte City, MO
Posted: 07/23/22 12:32pm Link  |  Quote  |  Print  |  Notify Moderator
Are speaking of the angled ones you drive up on? Andersen makes several types. I have seen it mentioned that people have had them break, but don't know that for a fact.
Howard and Peggy
"Don't Panic"
Durb
NW
Posted: 07/23/22 03:55pm Link  |  Quote  |  Print  |  Notify Moderator
They work great, but will slip on some surfaces so use the rubber pad which fixes the problem. I did have one break on asphalt (10,500# trailer). I emailed them a picture of the broken unit and Andersen sent out a new one swiftly.
I did try a different brand off Amazon as it looked heavier duty and came with a carry case. The ramp angle on it was too steep and the trucks e-brake wouldn't hold on it to get the chocks in. The smooth radius on the Andersens is a better design than the Amazon product.
Some complain they interfere with chocking their tires. I use Rotochocks so it isn't an issue for me.
pianotuna
Regina, SK, Canada
Posted: 07/23/22 08:11pm Link  |  Quote  |  Print  |  Notify Moderator
I know it for a fact. One of mine broke while I was sleeping. It was quite a loud noise.
Regards, Don
cbshoestring
Penn Hills. PA
Posted: 07/24/22 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Had one slip, I haven't used since. I feel much more secure driving up on the interlocking blocks.
Esacnj
NJ
Posted: 07/25/22 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
I am also concerned that when you try to take the chock out from under them that you may have to back up to release the pressure to remove the chock and may come off the back of the leveler which wouldn't be good.
valhalla360
No paticular place.
Posted: 07/25/22 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Having seen them on a few youtube videos, I don't see where they are significantly better than a few pieces of 2x8.
Generally will find a different site if it needs more than 2 boards.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Cummins12V98
on the road
Posted: 07/25/22 07:35pm Link  |  Quote  |  Print  |  Notify Moderator
They break! Really a horrible idea. Pack some lumber with and be done with it.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
