RV.Net Open Roads Forum: General RVing Issues: Scary tire change
 > Scary tire change
free radical
Canada
Posted: 07/23/22 06:15pm Link  |  Quote  |  Print  |  Notify Moderator
Bus grease monkey chanel
https://youtu.be/AENVARxXdSs
dodge guy
Bartlett IL
Posted: 07/23/22 07:05pm Link  |  Quote  |  Print  |  Notify Moderator
Glad you posted this. I just finished watching it and then came here to catch up. I hope Loves does take care of him like they said they would do! It’s scary to know what they may have put out on the road!
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
JRscooby
Indepmo
Posted: 07/24/22 06:49am Link  |  Quote  |  Print  |  Notify Moderator
I'm having hard time seeing the issue. Is the rant the inner nuts are loose after the outer are removed? If so, that is to be expected any time you deal with Budd wheels. The threads on outer is much larger than inner. Torque applied to outer, friction in the threads turn the inner. If somebody has lubed the inner threads the inner nut comes off stud before nut come off. You need a real short box end wrench to hold the outer, screw inner. Best case, if not removing inner wheel, you torque the inner nuts before put outer wheel back on.
One place in clip it looks like they but outer nuts on inner to torque the inner. I'm sure they got them tight, but did they stay tight when removed nuts to put outer wheel on?
dodge guy
Bartlett IL
Posted: 07/24/22 05:42pm Link  |  Quote  |  Print  |  Notify Moderator
What??? [emoticon] none of that makes sense!
Did you not watch the video. They used a 1” impact which over torqued the lug nuts/studs and stripped them out!
FlatBroke
CO/AZ
Posted: 07/25/22 07:32am Link  |  Quote  |  Print  |  Notify Moderator
20 minutes. More like boring tire change. No, I didn’t watch it all.
Hitch Hiker
"08" 29.5 FKTG LS
JRscooby
Indepmo
Posted: 07/25/22 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
I did enough tire work to not enjoy watching.
First time my first truck with Budd wheels needed brakes I broke enough hand tools before loaded parts and cooler of beer, went to tire shop to never richard around like that again. Next brake job, inch drive long shank impact. Probably 1000s of wheels off/on without striping studs, on Budd wheels. Now I did learn that putting inner tire on board to change outer wheel could lead to broken studs.
Cummins12V98
on the road
Posted: 07/25/22 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
It's the Morons that think it's ok to use a torque stick that cause many problems.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
time2roll
Posted: 07/25/22 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Please don't take your antique bus to a modern truck stop.
675w Solar pictures back up
free radical
Canada
Posted: 07/27/22 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
Why not
Id hope all tire shops repair people should be trained and qualified to work on any vehicle including heavy rigs.
time2roll
Posted: 07/27/22 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
Hope is great until a near impossible part to replace is broken or damaged.
Would you take your 1966 Ferrari or Shelby to the local guy on the corner? I sure would not.
 > Scary tire change
