RV.Net Open Roads Forum: Coleman Mach AC won't do anything - no fan, no ac
 > Coleman Mach AC won't do anything - no fan, no ac
mikec35
Seneca, SC
Posted: 07/24/22 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Coleman 9330e715 in my popup. I used an adapter to plug into my garage and ran the AC for about 10 seconds then it tripped the breaker in the garage. I have since wired in a 30 amp 120v box and plugged the campers electrical cord into it. I checked the voltage at the box and I have a surge protector, both checked out ok. I can plug things into the outlets and they work. The AC won't turn on, nothing, no fan, no ac... I checked the circuit breakers, none were tripped but I turned them off and on just in case. I checked all my fuses in the panel and all are good. Any idea where to go next? This unit has the controls on the unit itself, no remote thermostat. Thank you
3 tons
NV.
Posted: 07/24/22 03:02pm Link  |  Quote  |  Print  |  Notify Moderator
Not too sure about your Coleman, but the first thing to check is to see if the t-stat (wall mounted??) uses a battery…Beyond that, I’d want to pull the cover off to access the power terminals for further eval…
3 tons
enblethen
Moses Lake, WA
Posted: 07/24/22 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Remove the ceiling cover, verify that you have 120 volts entering the unit. Check the connector to ensure that they connected securely.
Turning breaker off without applying light pressure toward off doesn't always reset breakers.
An improperly wired RV may have run AC unit through a GFCI receptacle. Verify that the GFCI receptacle is not tripped.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
EMD360
Arvada, CO
Posted: 07/25/22 09:35am Link  |  Quote  |  Print  |  Notify Moderator
Had this problem. Air conditioner will not run without the fan. At least on my Coleman Mach 10. It’s easy to replace the capacitors. Mine did not have a start capacitor like the older ones (2018) so I sent that back and replaced the fan capacitor. Then I replaced the run capacitor because the fan worked but not the air. That fixed it.
Check that the fan spins freely. Check that the barrel fan above the filter spins freely too. If it’s the fan motor it can still be fixed but that part is more expensive. Still less than a new unit.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
mikec35
Seneca, SC
Posted: 07/25/22 11:06am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the replies. I pulled the control panel down from the ceiling and I do not have 120 volts to the control panel. Is there anything inline between the breaker and the AC unit?
3 tons
NV.
Posted: 07/25/22 11:30am Link  |  Quote  |  Print  |  Notify Moderator
No, have you checked at the breaker??
Upon re-read, you say the fan won’t come on, yet I believe the fan portion is 12v?…This should tell us something…
3 tons
mikec35
Seneca, SC
Posted: 07/25/22 11:53am Link  |  Quote  |  Print  |  Notify Moderator
I flipped the breaker on and off but have not put a meter to it. That is my next to do... I am bouncing in and out to work on this thing between work calls today. The 12v portion of the unit is what I am curious of. I am not sure how that works. The unit has a built in thermostat, not a separate wall thermostat. Does the fan itself operate off 12 volts?
enblethen
Moses Lake, WA
Posted: 07/25/22 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
There should be a Molex style connector at the control knob and a wirenut type splice. Check pins in connector to ensure they have not slide back and not making connection.
I am still thinking circuit breaker not completely tripped. Turn off all breakers applying light pressure toward off. Then turn on main breaker, if equipped, followed by other breakers one at a time.
3 tons
NV.
Posted: 07/25/22 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Sorry, I stand corrected, I just checked my Coleman Mach 1 and the fan will not operate without 120v…
3 tons
NV.
Posted: 07/25/22 12:27pm Link  |  Quote  |  Print  |  Notify Moderator
Try this,
https://www.youtube.com/watch?v=VSgIk8S_i-c
3 tons
