RV.Net Open Roads Forum: Coleman Mach AC won't do anything - no fan, no ac
 > Coleman Mach AC won't do anything - no fan, no ac
opnspaces
San Diego Ca
Posted: 07/25/22 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
Could you have flipped the hot and neutral wires when you added the 30amp circuit? Do you have one of these testers you can use to verify the wiring?
Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
3 tons
NV.
Posted: 07/25/22 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
We’re all rooting for ya [emoticon]
Posted: 07/25/22 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Ah. Thought strikes
Normally the 120 volt power lead is one continuous run of Romex from the Breaker box to the A/C (however there is no guarantee)
Now rodents love to chow down on romex but I'm inclined to think not
Two issues I have personally seen.
Bad connection.. A/C end of cable (Where the Romex connects to the Flexible wires in the A/C) they often use wire nuts and ... Not the best connectors.
Check for any evidence of arcing or burning NOTE THIS can trip breakers both on the RV's breaker box and the outlet feeding the RV.
Other thing I've seen.. Joke. sort of. many RVers have a few screws loose.
When my rig was New (less than 1 year) I had major A/C issues. Sometimes one worked, Sometimes the other.. both or none.. Ok so I started at the breaker panel.. Noticed when I was pokeing around (Safely.. I'm trained in that kind of thing) wires MOVING in the clamps.. Uh. That's not right.
one screw took a full 3 1/2 turns before I was happy Others took over 2 full turns) Yup they stuck the wire in but never tightened it down.
mikec35
Seneca, SC
Posted: 09/19/22 06:21pm Link  |  Quote  |  Print  |  Notify Moderator
Well, I'm an idiot!
I forgot to plug the outside cord into the top of the popup before raising it. I have yet to go camping with this camper so all the hookup procedures aren't second nature yet. I thought I'd update this thread at the expense of my dignity in hopes that anyone researching the same problem will check the obvious. Thanks for all the help!
