ReneeG
Meridian, Idaho
We had an estimate last year of $5k (around that) to replace the roof on ours when it's ready. It's not ready yet.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley TrailerSaver BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
NamMedevac 70
Reno
Once Upon A Time in America there were quality built RVs such as my 2001 R-Vision Trail Cruiser Lte TT owned by Monaco Coach. Many years of towing and camping use often in harsh conditions and on rough roads with no serious issues at all. Very hot Texas and Nevada sun on outdoor storage lots caused no harm except for some fading of decals and deterioration of roll up awning due to my bad. Those were the days.
Johnnybgood
Illinois
Check into rv flex armor roof. rvroof.com Had a quote of 5000 for our 35 foot a few years ago. Lifetime warranty.
ReneeG
Meridian, Idaho
Johnnybgood wrote: Check into rv flex armor roof. rvroof.com Had a quote of 5000 for our 35 foot a few years ago. Lifetime warranty.
Not meaning to hijack this, but thank you for this information.
Thermoguy
Graham, WA
I'm surprised how many RV's I see headed down the road with a big bubble of roof in the front. Seems like a more than typical problem. I would think an inspection (for caulking, etc) you would see stretch marks and wonder why it looks that way. More people need to look at their roofs.
Chuck ..
Salem, Oregon
RE: Rhino ECO Roof Replacement vs. TPO or Rubber???
I posted this a couple of years ago. Sorry that the pictures didn't come through. Roof still looks great. Look at the DRV Forum, under Problem & repairs to see pictures This year, I took on completely re-coating my RV roof with Henry 877 Tropi-Cool 100% Silicone White Roof Coating. Products cost about the same online or Home Depot. $239.89 for large tub of Henry's coating and $12.99 per tube of caulking. If you see from my previous post a couple of weeks ago, I did a lot of research trying to find the best product to repair/re-coat my RV roof with. I worked like a dog for nearly a week trying to beat the Fall weather. Wished I could of done the roof repair/coating in better weather conditions. Sweating bullets all week worrying about the possibility of rainy weather. Below is my step-by step process, along with before/after pictures. CAUTION! Slow down on the roof. If you fall off you will probably spend a lot of time in the hospital recovering if you are lucky! My Process Well it took me most of a week to completely re-coat my RV roof! Tuesday Morning Using a mixture of bleach, TSP, and water, hand scrub the entire roof (I did use a pressure washer to get the dirt out from under the roof air conditioner units). This took me a good part of the day alone! Peel off the old, very thin rubber coating Three and a half days later, wearing out a pair of leather gloves, I thought I gave it my best shot at getting off the old coating Saturday Afternoon Apply the new coating Clean out all of the old caulking above the roof gutter and replace it with new Henry's caulking. Mix the coating with a drill. Pour out about one quart into a paint tray. The Henry 877 coating pours out like the thickness of pancake syrup. Use a leaf blower to blow off any material laying on the roof Begin applying the Henry 877 using a four inch paint brush to do the corners, sides, roof pipe outlets, vents and air conditioners. I only did a 5 to 7 foot section at a time. Use a 9 inch long by 1/2 inch nap paint roller to spread out the Henry's roof coating. This took about two to three hours to fully cover the 8 foot wide by 34 foot long 5th wheel roof with one coat. On the next day, apply a second coat. I used about a full 5 gallon tub/container to do two coats. Lessons Learned: Try to apply the coating on fairly calm day. The wind can carry the coating in the air when applying it. I applied the coating when the temperature was in the mid 60's to upper 68 degrees. Sun helps, but I cannot imagine trying to apply Henry's coating or any other roof coating on a day when it is approaching upper 70 degrees or higher. Too hot for me to do a roof!. The roof must be completely dry before applying the new coating. During the Fall season, moisture in the morning is hard to dry off the roof, you may have to wait for the sun to come out. Dampness or morning dew can take several hours to dry off the roof. Give yourself plenty of time to do a good job. The faster you try to apply the roof caulking or roof coating you are most likely to do a sloppy job and have a mess. Conclusion Got lucky this time around! Henry's 877 when on fine, thick enough to be impressive and I believe I made the right product choice. * This post was last edited 11/26/20 05:30pm by Chuck
Chuck
dougrainer
Carrolton, Texas
Thermoguy wrote: I'm surprised how many RV's I see headed down the road with a big bubble of roof in the front. Seems like a more than typical problem. I would think an inspection (for caulking, etc) you would see stretch marks and wonder why it looks that way. More people need to look at their roofs.
Believe it or not, but doing an inspection on a roof will rarely show WHERE the air is coming in. You will see the result of air billowing, but a direct visual cause is rare, unless the rubber has actually pulled out of the front cap sealed aluminum strip. I have had air coming in thru clearance lights in the front cap and on the top front side clearance lights and also from below by the hitch area. Doug
PButler96
Midwest
dougrainer wrote: Thermoguy wrote: I'm surprised how many RV's I see headed down the road with a big bubble of roof in the front. Seems like a more than typical problem. I would think an inspection (for caulking, etc) you would see stretch marks and wonder why it looks that way. More people need to look at their roofs.
You don't need any air coming in for a roof membrane to balloon up, it's uplift from the air moving over it at speed, the same that happens with high winds sucking a roof off a house, which is not caused by the wind blowing in the windows and doors, although that would help it along. It's the same principle that lifts a 737 off the ground. Its not the the air under the wing pushing it up but the pressure differential between below and above the wing.
I have a burn barrel in my yard.
94-D2
Sutter Creek ca
Getting my edpm roof replaced as we speak. Insurance is paying Ca dollars and it is just short of 12k.
Mine is getting replaced down to the wood. I don’t know if the layers are individually replaceable or if they are bonded together as one. That could be the difference in cost (5k vs 12k). I looked at two providers and the price was about the same.
2018 Ram 3500 Crew Cab Laramie 6.7L, Aisin, air ride, Ram puck prep, SuperGlide 20K auto slide.
2018 Bighorn Traveler 4 slide w/Apt.
It’s not what you’ve done that commands respect, it’s what you do.
Happy Campin’
nickthehunter
Southgate, MI
Bumpyroad wrote: valhalla360 wrote: Saw a relatively new 5er headed the other way on the freeway today.
The rubber roof was wrapped around the air/con and flapping away...no signs of impact.
Unfortunately, there was no way we were going to get turned around and catch up to them, so it was still flapping away when I lost sight of him.
that is why I advise them on my CB radio of the problem.
oh, they don't have a cb, tough.
bumpy Hello - 1970’s calling, they want their cb radio back!
