enblethen
Moses Lake, WA
Look around the battery compartment for other end.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
dougrainer
Carrolton, Texas
Since the wires are OEM. It may be for a small 500 watt Inverter to power the entertainment system. Those were popular back in the mid to late 1990's. Fleetwood used to have the Power center(Power Converter/12 volt fuse block above the refer back then. But if the wires go in the roof they come out someplace else. Either the Coach battery compartment or by/behind the 12 volt coach fuse center or behind the 120 breakers. Doug
bobsallyh
Livingston, TX.
What type of range hood do you have? If 12 vdc light and fan, do they work or never hooked up?
Sjm9911
New Jersey
Does your camper have a radio/ audio system? My cd/radio wires are behind my microwave. The radio is under the cabinet next to my stove. So they feed out the side.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
