MrWizard
Traveling
![[image]](https://i.imgur.com/pLeDEOtl.jpg)
Doug ? Anybody ?
Know what these unused wires are for, Red Black pair appear to be for D.C. power, Microwave quit working, i removed it for replacement and found these spare wires, not a good spot for solar wiring too the batteries
1997 Bounder 36S
I can explain it to you.
But I Can Not understand it for you !
Connected using T-Mobile Home internet and Visible Phone service
1997 F53 Bounder 36s
enblethen
Moses Lake, WA
Prewired for 12-volt microwave?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
Many RV's are made with "Standard" wiring harness.. They use the wires they need. And leave the rest "N/C" (not connected)
QCMan
Independent Republic of Horry
Is there any voltage to them? Also, the rest of the wires seem to be overhead and those wires head off to the left. They look a bit too big for unused external speaker wires so that is out. What is off to the left as they seem to go in between the lower cabinet trim panel and the floor of the cabinet but you probably noticed that already. Keep us posted as that is a good mystery!
2020 Keystone Cougar 22RBS, Ram 1500, two Jacks and plenty of time to roam!
The difference between genius and stupidity is that genius has its limits. A.E.
Good Sam Life Member
valhalla360
No paticular place.
"Real men" always have extra parts because they are that good.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
dougrainer
Carrolton, Texas
enblethen wrote: Prewired for 12-volt microwave?
Never been a 12 volt Microwave for RV's. Doug
monkey44
Cape Cod, MA and Central Fla
Could be direct wired from a generator compartment, if you have one.
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
profdant139
Some of those wires look like 10 gauge?? If so, maybe this was for an inverter, using heavy wire to minimize voltage drop.
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
enblethen
Moses Lake, WA
Maybe not a true 12-volt microwave but run 120-volt microwave via an inverter.
MrWizard
Traveling
The wires go to right and into ceiling with the other wires, there is no voltage,, the DC fuse panel is only 3 ft away directly above the fridge, im dure these are spare 12ga red&black 12vdc type wiring, , i just wonder what for, extra light, another fan, range vent works, ceiling vent works,, all the lights work, its my inate curiosity that is piqued
