RV.Net Open Roads Forum: Fifth-Wheels: Fifth wheel mileage question
 > Fifth wheel mileage question
ReneeG
Meridian, Idaho
Posted: 07/28/22 06:55am Link  |  Quote  |  Print  |  Notify Moderator
I agree with the person who said heavier FWs often equate to quality. I also agree with the two that said, don't sweat about the mileage; pick the floor plan that works best for you. On that, I have to add that after four travel trailers and knowing what we liked and didn't when we started looking for an FW, we had every salesperson bring the slides in so we could see what that felt like as far as walking around when we stopped at a rest stop or had to spend the night in it that way at an overnight stop. That was an eye-opener. In our FW, we can access all kitchen appliances, the commode, and can sleep in it, all with the slides in. Good luck in your decision.
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
valhalla360
No paticular place.
Posted: 07/28/22 07:05am Link  |  Quote  |  Print  |  Notify Moderator
Aerodynamics are the biggest issue but particularly in hilly/mountainous terrain, weight will have an impact.
GVWR is a good surrogate for what to expect the trailer to weigh. They don't put bigger beefier axles on unless they need them. You won't find a big difference in weight between trailers with similar GVWR. About the only exception I can think of would be if you compare a toy hauler to a standard 5er but don't take any toys. The toy haulers are designed assuming a fairly significant load in the garage.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
fj12ryder
Platte City, MO
Posted: 07/28/22 07:11am Link  |  Quote  |  Print  |  Notify Moderator
We usually averaged between 11-12 mpg towing our 12,000 lb. 5th wheel. We averaged around 10-11 mpg towing our 15,000 lb. toyhauler. Same truck, same height, same width, heavier trailer.
IMO, I'd be more concerned about length rather than weight. Length will affect your RV site choices.
Howard and Peggy
"Don't Panic"
TravelinDog
Nevada
Posted: 07/28/22 11:19am Link  |  Quote  |  Print  |  Notify Moderator
This is our 1st long trip with our new 5er, 14k gvwr. We've gone from so. NV to Reno-Elko-Boise-Lakeview-Medford so far. Tow vehicle is a 2017 Ram with Cummins 6.7.
We've driven from hot desert to high mountains and everything in between from 2700ft elevation to 7300 foot passes.
MPG has been anywhere from a high of 12.2 to 9.3.
Just say no to the payload police ">
lenr
Indianapolis, IN
Posted: 07/28/22 12:10pm Link  |  Quote  |  Print  |  Notify Moderator
2012 F-350 CCSB SRW 6.7 3.31 axle. 24' box 6500 lb., 27' fifth wheel 9400 lb., & 37' fifth wheel 13,500 lb all have averaged around 11 mpg. I believe that aerodynamis is most significant effect on towing mileage.
Durb
NW
Posted: 07/28/22 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Weight matters. Getting an extra two and half tons moving in stop and go traffic requires a lot of energy or fuel. Pulling an extra 5,000# up a hill also takes a lot of juice. Weight also matters when it comes to stopping your rig as retarding all that extra momentum will create a lot of heat energy which needs to be replaced as fuel.
I always strive to always keep my weight down as much as possible by loading lightly and leaving unneeded stuff at home. Lighter rigs are easier on your truck's drive line components and will result in fuel savings. Whether the savings are that important to you is something you will have to decide.
I'm of the opinion that blaming aerodynamics as the major source of poor fuel economy is a rationalization for towing heavy.
2112
Posted: 07/28/22 03:14pm Link  |  Quote  |  Print  |  Notify Moderator
My last 6 trips or so have been traveling the exact same 350 mile route going to visit her aging mother. I average between 8 and 13 MPG a trip. The only difference is the wind. This is with a gasser however
2013 KZ Durango 2857
